Old 10-28-2015, 06:42 PM   #11
B and B's Avatar
The installed factory filter does both tank water and city water in my trailer.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 10-28-2015, 07:12 PM   #12
Blackhat6mike's Avatar
X2, but my toilet line Tees off pre-filter and post check valve of the city water. Always had super water pressure at the toilet except when it was new and stopped up with plastic trash. Cleared it out and has worked fine since.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 10-29-2015, 07:50 AM   #13
Originally Posted by gastan View Post
I never carry water in my TT. The type of camping we are doing presently puts us in camps that always have a water connection so I don't see the sense in carrying around all that extra weight. For those rare times we might need to spend one night pulled over in a parking lot just to sleep, we plan ahead and carry 4-5 gallon jugs of water for morning coffee and other needs.
My question ... does a city water connection go thru the water filter? Or does it by-pass it with the assumption that a city connection is already filtered? Just wondering if I need to continue to change the filter every year or not.
Thanks.
I would still use an in line filter I worked at a campground all the plumbing was out dated iron pipe every time you turned water on you would get a shot of rusty water.
Myrle is offline   Reply With Quote
Old 10-29-2015, 08:07 AM   #14
mcnabbwr's Avatar
We travel to many different areas and are never sure of water quality. We utilize a dual canister filter system to remove sediment and improve taste. We run all incoming water through it wether it's tank or city side.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 10-29-2015, 08:11 AM   #15
northstar1960's Avatar
Originally Posted by D_B Travelers View Post
We are similar in that we camp with full hookups most of the time and the trailer has a system filter for all incoming water. That said we added city water to the fresh holding tank in Wichita KS this past June and finished our trip about a week later without emptying it out or having to use it. The water in the fresh tank developed a very bad odor which the main filter would not remove. We ended up dumping the tank, adding a chemical just for this purpose ( I forget which one) to the new fresh water and letting it sit for a week or so. It did get rid of the odor and we are good, but now we use an additional filter at the shore connection all the time. I have not noticed any drop in water pressure with both filters connected and now if we want to carry fresh water in the tank we can fill up knowing it is filtered. The blue filters that fit on the supply hose end are not expensive and are easy to use; I just dump the water out of mine and store it on top of the hose in the bay.
You got well water . it will start to smell like rotten eggs in about a week of storage . when ever i know i'm getting well water i make sure it's only in unit for a few days . will really get bad in hwh if left in
northstar1960 is offline   Reply With Quote
Old 10-29-2015, 08:31 AM   #16
WFD
Be careful with storing filters in the bay, on top of the hose as you say...if you are not using the trailer for a few days, a week, whatever, it gets awfully warm in those storage bays and whatever is in that filter can grow and become a science project...when not in use those filters should actually be stored in a fridge.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 10-29-2015, 08:42 AM   #17
kdot's Avatar
Filter for City Water
On the advice of my dealer, when winterizing, I took the filter out, wrapped it in a sandwich bag, and put it in the freezer compartment in the house refrigerator. He said that would kill the bacteria in it and I could put it back in the canister next Spring. Does that seem like good advice?
kdot
2017 RPod179
2016 Honda Pilot
kdot is offline   Reply With Quote
Old 10-29-2015, 09:17 AM   #18
Thanks for all the great answers. I'll keep replacing the filter each year. And after reading some of these answers I think I'll look into an inline filter as well.
2012 Rockwood MiniLite 2104
gastan is offline   Reply With Quote
Old 10-29-2015, 09:45 AM   #19
mcnabbwr's Avatar
kdot
I would replace it every year at least. Due to usage I replace a minimum of twice a season.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
Old 10-29-2015, 03:54 PM   #20
thebrakeman's Avatar
Originally Posted by Blackhat6mike View Post
I have an onboard filter that all water EXCEPT to the toilet flows through it. Why filter toilet water other than to keep trash out? The pump and T to the toilet are prefilter.
Maybe these were rhetorical questions, but:
Either way, we probably all change the onboard filter every year. It's not like filtering the water going to the toilet will cause anyone to change the filter more often (unless perhaps you're full-time, and actually use a counter).
Plus, that's a 3rd water line that has to be run to the bathroom. Which means more antifreeze to winterize. For me, that would mean having to purchase a 2nd gallon, then store most of it til next year.
thebrakeman is offline   Reply With Quote
water
