Old 10-29-2015, 04:01 PM   #21
thebrakeman's Avatar
Originally Posted by kdot View Post
On the advice of my dealer, when winterizing, I took the filter out, wrapped it in a sandwich bag, and put it in the freezer compartment in the house refrigerator. He said that would kill the bacteria in it and I could put it back in the canister next Spring. Does that seem like good advice?
kdot
When winterizing, I remove the filter from the clear housing, and trash it. I then fill the clear housing with clean, washed pea gravel, which I keep specifically for this purpose (the same gravel every year). That way, I'm not having to fill that housing with antifreeze. Same principle as a hot-water bypass, only on a smaller scale. As previously mentioned, I'm just barely able to get by with a single gallon of AF.
I know, AF is cheap. But so am I.
Anyway, new filter goes in the next spring. They are only $10 for 2 at Walmart. The 2nd filter goes in a ziplock for next year.
thebrakeman is offline   Reply With Quote
water
