Old 10-29-2013, 06:11 PM   #1
Class a water pump stops running
WINTERIZING MY 2011 373DS MOTORHOME TODAY...WHEN TRYING TO PUT ANTIFREEZE IN SYSTEM THE WATER PUMP WOULD RUN AND SUCK IN ABOUT 1/2 GAL AND STOP RUNNING..THAN START RUNNING AGAIN WITHOUT DOING ANYTHING TO IT..DID THIS FOUR TIMES UNTIL GETTING 2 GAL IN SYSTEM..ANY IDEAS ON THIS....THANKS FOR YOUR HELP IN ADVANCE
pennstaterv is offline   Reply With Quote
Old 10-29-2013, 07:02 PM   #2
VinceU's Avatar
The pump stops because its reaching cutout pressure. Try "cracking open a valve far from the pump to allow air to escape. Then close that valve when the pink arrives and open another. Air escape quickly, not nessary to open fully.
pump, water, water pump
