Old 08-13-2016, 01:36 AM   #1
Cleaning the toilet, help
So our new to us, 2009 Rockwood trailer, has a stinky toilet. The toilet bowl is clean, but under the ball, its disgusting. The water does not flush out all around under it, and I am trying to figure out the best way to clean it. We had an Outback trailer previous to this one, and it had a porcelain toilet that had a pipe straight down, but this stupid plastic toilet doesn't. Its wider under the ball, and if whatever you flush doesn't drop straight down, it can hang around under there. I am soo grossed out by this. Any ideas how to clean all the poop out of there? Coat hanger and wadded t.p. sprayed with bleach solution, or?? Help!!!
Sunny Sunshine is offline   Reply With Quote
Old 08-13-2016, 02:47 AM   #2
welcome to the world of camping where the crap drops straight down in to the black water tank.
Before using toiled ADD a couple inches of water to the tank and some toilet toilet chemicals.
Before each use, add a couple inches of water to the toilet, take your crap, flush the toilet and let a bit more water run into the tank, slowly close the ball and allow an inch of water to remain in the toilet
Problem SOLVED
or you could use th outhouse instead
ShermanD is offline   Reply With Quote
Old 08-13-2016, 04:04 AM   #3
You can try one of these to clean the space under the ball.
2015 Sunseeker 3170ds
TakeItEasy is offline   Reply With Quote
Old 08-13-2016, 06:43 AM   #4
Sprayer
This is just one version of this idea ( I saw a different one 1st time but can't find it now) Sprayer for Toilet
Cmessmore is offline   Reply With Quote
Old 08-13-2016, 06:59 AM   #5
No-Fish's Avatar
I saw a sprayer in a 2017 Forester 3011, I think you can get the kit to add one , from any RV parts site
Happy Flushing LOL
No-Fish is offline   Reply With Quote
Old 08-13-2016, 12:12 PM   #6
I read your post as poo under the loo...as in the shaft running down TO the black water tank. I had that problem with a used 2008 Starcraft. I used a cheap big lots toilet brush and started digging. It cleaned up with some cleaner and hose sprayer. I threw away the brush after I was done. It's a crappy job but not the worse thing you will ever need to do in your life.
randman132 is offline   Reply With Quote
Old 08-13-2016, 12:27 PM   #7
You can buy a toilet wand at any RV parts store. Just make sure you close the ball as far as you can so it doesn't spray off the underside of the toilet and hit you in the face. Not that I would know anything about that mind you.
_____________________
Berk Thompson
TT 2013 FR V Lite WIKSS
TV 2013 Chevy 2500 Crew Cab
Middleburg Redneck is offline   Reply With Quote
Old 08-13-2016, 12:30 PM   #8
Is it a Dometic 300? I know Domectic was replacing 300's with 310's with ceramic bowl. Not sure if that is still the case. You could replace the toilet.
markb422 is online now   Reply With Quote
Old 08-13-2016, 12:31 PM   #9
YES...I forgot that part...keep your mouth closed during the operation.
Old 08-13-2016, 12:53 PM   #10
Evereddie's Avatar
To do it right I would replace the toilet. There was a recall at one point so you might get help from Dometic. In the process of replacing the toilet you can analyze the situation below, clean it, and maybe modify it so it stays cleaner.
Evereddie is offline   Reply With Quote
cleaning
