Old 12-29-2015, 04:24 PM   #1
hillmh's Avatar
Clog in fresh water system
I drained and cleaned my hot water tank and a bunch of calcium or some other flaky white crud came out. When I reconnected to "city water" and tried to run the kitchen faucet some of it must have still been in the system and clogged up the aerator. I took it off and cleaned it but am still only getting a trickle. All the other faucets and toilet work fine. any ideas where the clog might be?
2015 Coachman Apex 23.5BHS
2015 Ford F-150 Ecoboost
hillmh is offline   Reply With Quote
Old 12-29-2015, 04:53 PM   #2
There is another screen at the input to the faucet that is also clogged.
Bill
2015 Charleston 430RB
Billr is offline   Reply With Quote
Old 12-29-2015, 05:08 PM   #3
fonzie's Avatar
most likely the faucet valves are plugged
Fonzie
Old 12-29-2015, 06:00 PM   #4
faucet screens- take the faucet completely apart- seen it many times- comes from factory clogged sometimes
riverrat958 is offline   Reply With Quote
Old 12-30-2015, 12:05 PM   #5
I have removed the faucet screens till was convinced all debris was flushed out of lines, and.system.
Myrle is offline   Reply With Quote
Old 12-30-2015, 05:01 PM   #6
When you drain hw tank use flush wand to clean the crud out. Helps a lot
Harkerr is offline   Reply With Quote
Old 12-30-2015, 07:57 PM   #7
Evereddie's Avatar
So exactly what is that white crud in the tank?
Evereddie is offline   Reply With Quote
Old 12-30-2015, 08:44 PM   #8
I believe a combo of calcium of some sort and residue from the spent anode material
Old 12-30-2015, 08:52 PM   #9
Ford Idaho's Avatar
Plastic?
When the holes for fittings are cut in the tank/s it is not cleaned out.
So it gets in water lines. filters and your wallet.
Old 12-30-2015, 09:01 PM   #10
Evereddie's Avatar
Originally Posted by Ford Idaho View Post
Plastic?
I had the white crud after the first, second, and third season. Only used the fresh water tank for a couple of flushes now and then on the road. Never ran it through the water heater so don't think that it is plastic, in mine anyway. I think of the crud as 'fall out' but in reality I think it is minerals that get excised from the water by the heating element and how hot it gets. It's the same as the crud that develops in your home water heater. You are suppose to drain your water heater at home yearly to get rid of this stuff.
NOTE: Just read up on several other RV forums and "Crud" is the official name for it. Also the crud is minerals from the heat of the heating element and some recommend not leaving the element turned on all the time. For me , I'll just leave it on and flush my water heater tank.
fresh water, water
