Old 05-17-2019, 05:32 AM   #1
Bob-0's Avatar
Close Call
Our second trip in our new 5th wheel. Decided to try out the propane side of the water heater. Good thing I stuck my head out the door and looked back. Someone vorgot to tighten the connection to the gas valve! Spent the rest of the day checking all gas connections.
Bob-0 is offline   Reply With Quote
Old 05-17-2019, 05:40 AM   #2
Did you put Tef tape on those fittings ? Most of the copper/brass fittings...flared or compression...do not require, nor is it recommended that tape be put on the threads.
TheWolfPaq82 is offline   Reply With Quote
Old 05-17-2019, 05:58 AM   #3
wmtire's Avatar
Can I ask why you have the electric heating element cover off. It's laying beside the teflon tape and goes where I have the red lines drawn (as per the second pic). I am just wondering if this was left off or fell off for some reason.
Also, what I have circled , is this burn marks on your trailer from the water heater?
ID:	204771   Click image for larger version
Name:	electric element cover.jpg
2011 Flagstaff 831 RLBSS
Never Apologize! Never Explain!
Sorry, thatís my motto.
Old 05-17-2019, 06:16 AM   #4
nomad297's Avatar
This is correct. The only place you should use PTFE tape is on tapered threads. Thatís it.
Bruce
Old 05-17-2019, 06:57 AM   #5
Bob-0's Avatar
Cover
Yes the cover is off. I was checking for power to the element. And yes that is a burn or soot from raw gas and wires were also burnt in the process. Flames were a 1-1/2 feet high. Like I said, good thing I looked out the door right away. My other trailer had a switch inside for gas and electric. This one has a switch for gas inside and a switch on the tank for electric.
Old 05-17-2019, 07:05 AM   #6
wmtire's Avatar
That sure could have been catastrophic. Hope you get back with your dealer/manufacturer on this, since it's a new RV.
As far as the switches, you have a Suburban SWDE model water heater. This FAQ explains the operation of:
Suburban's electric switch and much more
Old 05-17-2019, 07:17 AM   #7
I liked that same set up my old Jayco.
