Old 03-18-2019, 03:36 PM   #1
cloudy strainer
I just sanitized my travel trailer and after flushing I noticed my strainer is cloudy and I am not sure why. Everything I flushed was clear should I drain the water and pull the strainer?
tjjoyner is offline   Reply With Quote
Old 03-18-2019, 03:41 PM   #2
Mr. Dan's Avatar
You don't say what type/brand of travel trailer you have... but what are you calling a strainer?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 40; booked = 49
Old 03-18-2019, 09:10 PM   #3
forest river ultralite 21ds and the strainer is located at the shurflo pump.
Old 03-19-2019, 12:07 AM   #4
bikendan's Avatar
The OP has a Flagstaff Micro-lite 21DS.
Equalizer WDH
Old 03-19-2019, 12:54 AM   #5
Just as confused as you
Scrapper's Avatar
What did you use for sanitizing and what was the mixture ratio?
Richard & Jill
Camping since 1989, seasonal since 2000
Old 03-19-2019, 09:18 AM   #6
1/4 cup bleach per 5 gal.water
Old 03-19-2019, 09:44 AM   #7
D W
D W's Avatar
Happened to me last year. Like the OP said, water ran clear out of the faucet. I just pulled the strainer cup off and cleaned it out, sanitized it and put it back together. Don't know what it was, but the stainless steel screen caught it.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator Mods- Reprogrammed 4L80E
2016 Salem 27RKSS (Pacific Northwest Build)
D W is offline   Reply With Quote
Old 03-19-2019, 09:51 AM   #8
Cloudy ? or are you seeing turbulence in the strainer due to flow thru the pump.
TheWolfPaq82 is offline   Reply With Quote
Old 03-19-2019, 02:15 PM   #9
Scrapper's Avatar
The bleach should be ok but you mixed it stronger than it needs to be. 1/4 cup of plain unscented bleach per 15 gallons. Unless you used the wrong type.
Use the plain (and generally least expensive) unscented household chlorine
bleach with at least 5% sodium hypochlorite found in supermarkets; do NOT
buy fresh scent, lemon or other scented chlorine products. Do not use bleach advertised as splash free or proof. Do not use either acid or alkaline bleach solution. Solution with pH 6-7 is best.
Richard & Jill
