Coachmen Clipper 16 Water inlet/pipe/connection leaked inside, loose connection help
Hello
Our Coachmen Clipper 16 started leaking all over inside.
The Water inlet/pipe/connection leaked inside, and the connector on the outside is loose and inside it has a loose connection. Has anyone else had this happen to their Clipper? How do we fix this? We tried tightening the inside black but that tightens the water inlet to the wall. However its still loose. Any help on this issue would be appreciated. Thank you in advance!
Coachman Clipper RBD 2015
Ford Expedition EL XLT
-to 2005 Jayco PUP -- Then back to Cabin Tent (large)--to Palamino PUP (small) - From Tent
