Old 01-30-2013, 11:17 AM   #11
Originally Posted by Ragin Cajun View Post
BTW...what's the best method to remove the clamp without tearing up the pipe?
I used a very small screw driver and worked it under the tail end of the clamp. There are little thorns that stick out from the under layer that hook into the outer layer. Basically, you're trying to pry the 2 layers apart so that thorn lets go. (Man, I suck at descriptions! )
My attempts at cutting the clamped portion proved futile.
Getting the clamp off was actually the hardest part of my fix.
2013 Sabre 36QBOK pulled by a 2012 Ram 3500 DRW
Blogs: Learn to RV & Personal Fulltiming Adventure
Towing Calculators: Towing Planner
Old 01-30-2013, 11:44 AM   #12
The tool that jim showed you is not the correct type for pex. I have used that type of clamp in my house and this is the tool I used Waterline | Surlok Starter Set With Rings | Home Depot Canada
It has the stops built in so you do not over crimp the joint. In the picture it looks like the clamp has been over tightened. You may need to take the pex off the tube and make sure the plastic T is no damaged. You would then shorten the pex and start with a fresh end (if you have enough length in the pex line).
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 01-30-2013, 02:18 PM   #13
Camper Less Camping
Cajun Po-Boy's Avatar
Thanks tools and clamps today, will tackle before the weekend gets here!
Another great reason to be on this forum...2 heads or better than 1, or in our case thousands from this forum
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
