Old 10-01-2012, 11:05 AM   #1
Cold water pressure @ Galley sink
I have been on several trips since buying a RLSS31. At the galley sink the cold water has low flow I have not checked the pressure. The hot water @ the galley has good flow & pressure. The shower & bath are running good. Is there a valve I am missing, flush the line, or is or a fixture problem?
Don & Marsha Dupree
2000 Chevy K2500 6.0L
2009 Flagstaff, 31RLSS
dedupree is offline   Reply With Quote
Old 10-01-2012, 11:12 AM   #2
Triguy's Avatar
I would have said clogged faucet (which is common) but the hot water is fine at that faucet. My next guess is there might be a kink in the cold water line leading up to that faucet. Have you looked at the lines, yet?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 10-01-2012, 11:31 AM   #3
No but that is a good idea I checked under the sink @ the faucet but did not trace it back.
Don & Marsha Dupree
Old 10-01-2012, 11:57 AM   #4
hotrodj125's Avatar
Either a kinked line, a stop valve not on all the way, or debris in the line blocking the flow.
Rod & Linda Johnson
Cedar, Minnesota
2006 F-250 SD 4x4 6.0
2012 Columbus 320RS
K-9's Lucy & Lizzie
Enjoying Life 1 Campground at a time
hotrodj125 is offline   Reply With Quote
