Old 10-29-2015, 01:53 PM   #1
Confused....RV Vent Caps to Nowhere
Here we go....
Crawled on roof to replace factory sewer vent caps with 360 siphon.
3 vent caps in sight.
2 of the vent caps had no pipes and were just covering a hole in the rubber and plywood.
Why? Mistake? Moisture prevention? Some other reason?
On the other side of the fence.....I have 1 black tank and 2 grey tanks. Are they inter-connected to the only vent that had a pipe or is that another mistake?
Thanks for your replies....totally puzzled.
Chevy 3500HD Dually
XLR Thunderbolt 417amp
RZR XP 4 1000
TexasFamily is offline   Reply With Quote
Old 10-29-2015, 02:50 PM   #2
heavynlori's Avatar
Some units have attic vents in the roof
These are separate from your black and grey tank vents but look similar
heavynlori is online now   Reply With Quote
Old 10-29-2015, 02:56 PM   #3
Hmmmmh.....oops!?!
Do I need the attic vents?
Chevy 3500HD Dually
RZR XP 4 1000
Old 10-29-2015, 03:08 PM   #4
I had never heard of these before. Based on a little searching, a lot of people haven't. Many confuse them with the plumbing vents.
Iwritecode is offline   Reply With Quote
Old 10-29-2015, 03:15 PM   #5
Boss Ox & Drovergirl
oxcamper's Avatar
Our rear gray tank has a vent through the side wall.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 10-30-2015, 08:28 AM   #6
Mine has two vents that appear to be for the roof structure and are not for plumbing, but I haven't looked closely to tell for sure.
phillyg is offline   Reply With Quote
Old 10-30-2015, 08:37 AM   #7
Fulltime family RVer
Conduit to the basement of inside for wiring? I've been on a kick lately that RV manufacturers would do us all a favor if they'd just install one or two with a chase line to aid in aftermarket mods.
Old 10-30-2015, 11:16 AM   #8
Telstar's Avatar
You only need the 360 on the black tank.
The extra vent caps provide air circulation in the attic space much like the attic venting in a house.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
Telstar is offline   Reply With Quote
Old 10-30-2015, 06:38 PM   #9
Texas, I have the same configuration, 1 black and 2 grey tanks. I bought the 360 siphon and thought I needed 3 since that's how many vents are on the roof! I haven't installed them yet, but can you tell if there is a pipe before taking off the sealant?
atcla is offline   Reply With Quote
Old 10-30-2015, 08:04 PM   #10
VinceU's Avatar
Yes, remove one screw in cap, above roof. You'll see pipe or not straight away. Fakes can also hide wires for not purchased add ins. Very common to have two or three vents to combine to one termination.
fuse, vent
