Old 06-08-2015, 06:57 AM   #11
It's not necessary if you camp a lot and leave water in the system. I would recommend putting it in if you drain your tank when winterizing (storing). It only takes seconds to burn up the element if you turn it on without water in the heater. Yes, I did it once. when getting ready for the new season, I flipped the switch and a moment later realized I had not flipped the bypass valves to fill the tank. Turned it off, but the damage was done. Grrrr. Now I put it in and it acts as a reminder to check before I turn it on. Use the needle nose as suggested. It makes it a lot easier.
Bob and Joy
2013 Sunseeker 3010DS
rhumbert is offline   Reply With Quote
Old 06-08-2015, 12:10 PM   #12
Canadian Member
itat's Avatar
I am using needle nose pliers - I've tried both straight and angled needle nose. Its just very finicky.
itat is online now   Reply With Quote
Old 06-08-2015, 12:17 PM   #13
Oakman's Avatar
I reinstall the pin after winterizing so that in the spring I remember to make sure there is water in the tank before I use it on the electric side again.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
electric
