Another option is Loctite Plastic Bonder.
https://www.homedepot.com/p/Loctite-...0788/100371824
It sticks really well to all kinds of plastic and is durable as heck.
I used something similar from Loctite to re-attach a inside door handle on an old Ford Explorer. Lasted another 5 years before I sold it.
If the ends of the crack are visible, I'd drill small "stop holes" at each end. Just use the smallest drill bit you have, preferably less than 1/8". This will stop the crack from growing. Also, "V" out the crack using a small burr on a Dremel tool. Don't go all the way through the tank material, just the first half or so. this will both widen the surface the "Bonder" will attach to but also make a thicker layer of patching material instead of just a bead on the surface. Just like welding metal for a repair.
Stuff is a little pricey but a lot less than replacing the tank, especially when factoring in all the labor to remove and replace.
BTW, drain the tank first and make sure the repair area is dry. Compressed air and hair dryer, even tip trailer so any remaining water is away from damaged area.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
