Old 04-14-2016, 12:06 PM   #11
Jimsue's Avatar
Ha ha ha ... I stay away from my fingernails when I'm working on toilet drains!
I'm gonna fuss with it a bit, then try the eternabond since I have a some left from the repair of slide screw heads poking through my slide rubber roof!
Would I be better off silicone caulking it first, then eternabond ing? Or just eternabond? Thanks a million for your help.
2015 F350 Lariat Crewcab DPS SWD 4x4
2013 Sabre BKOK 31
Demco Hijacker Autoslid
Renogy Solar Suitcase
Progressive Industries EMS
Sea Eagle 420 Tandem Inflatable Kayak
Jimsue is offline   Reply With Quote
Old 04-14-2016, 12:22 PM   #12
Jimsue's Avatar
I really like the rubber splicing tape idea, so I can undo it at Goshen. Eternabond does not unwrap( ergo the name)
Thanks all for your prompt and helpful ideas.
2013 Sabre BKOK 31
Old 04-14-2016, 01:02 PM   #13
Gold Miner At Heart
Papa-t's Avatar
Anyone with plumbing experience can fix it. I understand you said that you don't. Do you know anyone that knows about plumbing. I had the same problem on a previous camper. I would agree to pull the toilet and cut out the old pipe and reinstall new. Have it fixed right the first time and then you won't have to worry about it again. I would rather have a plumber fix it right then take it to any RV shop.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
Papa-t is offline   Reply With Quote
Old 04-14-2016, 01:30 PM   #14
Jimsue's Avatar
Good point, Papa T... I didn't think to ask local plumbers. If I can assist, then I can learn . All my training in literature doesn't work here.😬
2013 Sabre BKOK 31
Old 04-14-2016, 02:01 PM   #15
I had one leaking also, I used the Flex seal spray, as seen on TV. It has been dry since, been about 9 months , put on 6-8 coats of it, Seems to really work good. It comes in different colors. So far so good.
2014 SUNSEEKER 3010DS
TOADS, 2012 FOCUS OR 1998 JEEP WRANGLER,
Kevin & Judy is offline   Reply With Quote
Old 04-14-2016, 05:56 PM   #16
Jimsue's Avatar
I am humbled by the show of support by the good people on this forum. Hope to be able to pay it forward...
2013 Sabre BKOK 31
Old 04-15-2016, 11:56 AM   #17
edt
Cut the pipe at the problem and add a rubber splice kit with hose clamps plumbers use this all the time
North Ga
2015 40' cls
Never to be moved
edt is offline   Reply With Quote
Old 04-15-2016, 12:02 PM   #18
B and B's Avatar
Fernco fitting and cut/replace or use some self vulcanizing electrical sealing tape. I have used this with hose clamp as a pressure bandage on steam lines in the past. In this case wrap the tape and cover with electrical tape. Will last for ever.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-16-2016, 03:25 PM   #19
Jimsue's Avatar
Here is the existing drain… Please advise as to where I should cut.Click image for larger version
Name:	ImageUploadedByForest River Forums1460838273.665432.jpg
ID:	105129Click image for larger version
Name:	ImageUploadedByForest River Forums1460838296.400392.jpg
2013 Sabre BKOK 31
Old 04-16-2016, 05:34 PM   #20
edt
Shop AMERICAN VALVE 4-in x 4-in Dia Flexible PVC Coupling Fittings at Lowes.com
cut any straight section and put back with this
North Ga
2015 40' cls
Never to be moved
drain
