Old 06-05-2016, 03:30 PM   #11
Broadway Joe's Avatar
Did anyone read where he is permanent for the season?
Joe
2015 Wildwood 27RKSS
2015 Silverado 2500HD Duramax
Broadway Joe is offline   Reply With Quote
Old 06-05-2016, 03:30 PM   #12
VinceU's Avatar
It can be done, I've had working probes for over15 years using a tank spray wand. You must forget the myth that saturated TP can hang over 6" vertically between probes. It's impossible. A film can build up over the same surfaces and is conductive enough to read on the output LEDs.
Wands can be located at Walmart or Camping World. You must mark the wand at the handle to locate the nozzle blast when applying the spray. Very important to know where the four tank sensors are to concentrate the spray. If you can have someone tell you when lights start to go out it speeds the process. Works for me....
Old 06-05-2016, 03:56 PM   #13
Originally Posted by aceinspp View Post
Did not say crushed Ice I said Ice cubes and it does work. Later RJD
Have a look at this video.
Old 06-05-2016, 03:56 PM   #14
ferguson65's Avatar
I also use the down the toilet wand when the gauge gets stuck. The built in black tank flush does help get the tank cleaner, but does nothing for the sensor. The wand is the only way I've managed to get them working again.
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
ferguson65 is offline   Reply With Quote
Old 06-05-2016, 03:57 PM   #15
bob dirt's Avatar
Why does that matter? Still needs to clean his sensors. IMO the best way is with a good steam of water and it should be rinsed out every time he flushes AND let the tank fill up pretty full before flushing. Just seems to work better.
YMMV
2016 Forester 2401WS MBS
Life is short...eat the cookie
bob dirt is offline   Reply With Quote
Old 06-05-2016, 04:04 PM   #16
I was referring to all the advice to use ice and drive around
Joe
Old 06-05-2016, 04:04 PM   #17
Install a Blue Streak and use 50-50 mix of Super Clean and water in it. Solves the problem.
Chemical Dispensing Systems for RV & Marine | Blue Streak LLC
Old 06-05-2016, 04:34 PM   #18
Our Puma Unleashed black tank meter said 3/4 the day it was brand new. (last July)
Last weekend someone visiting flushed several tampons and stopped up the .... tank.
Garden hose IN the toilet, let the tank completely fill 4 times and completely dump 4 times and now the black tank gauge works as designed!!! We have a factory installed black tank flush that has never helped the sensor issue.
Might be worth a try!
IF your shower head is as close to the toilet as ours (and you have a lot of patience), one could fill the tank through the toilet with the shower head if they so desired.......... Being a toy hauler, I simply drug the hose in through the garage to do the deed.
gilwilliams101 is offline   Reply With Quote
Old 06-05-2016, 04:46 PM   #19
OldGuysRule
Renegade837's Avatar
Thanks for all the advice. Seems one common theme is that the factory flush is useless. I use it every flush and flush only at full, but I think I'll have to get a wand.
Renegade837 is offline   Reply With Quote
Old 06-05-2016, 04:56 PM   #20
Georgia Frog Rally 2018
aceinspp's Avatar
Originally Posted by OldCoot View Post
Did not prove a hole lot. Trailer life even recommended to use and I have and all I can say it works have you tried? Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
black tank, tank, black
