Old 06-05-2016, 04:57 PM   #21
Georgia Frog Rally 2018
aceinspp's Avatar
Originally Posted by bob dirt View Post
Why does that matter? Still needs to clean his sensors. IMO the best way is with a good steam of water and it should be rinsed out every time he flushes AND let the tank fill up pretty full before flushing. Just seems to work better.
YMMV
Then some of the suggestions do not work. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 06-05-2016, 05:01 PM   #22
Originally Posted by Renegade837 View Post
Seems one common theme is that the factory flush is useless.
the factory flush is just a spray in all directions not a pointed jet,... and if its like our trailer it is mounted on the exhaust end of the tank, just above the drain line,..... before discovering that I would run my ff while draining, thinking that it was mounted on the opposite side and that it is helping to push the flow towards the drain, .... but since its on the drain side, if running the flush while draining, the spray is actually interfering with the flow towards the drain, so it could be holding back solids and paper that you want to flow out, ... so now I run the flush, then stop and open the drain valve and let it flow out,...... a few times of that routine and it is clean... my factory flush actually does do a good job of cleaning when using it this way,.......
fella10 is offline   Reply With Quote
Old 06-05-2016, 05:01 PM   #23
nomad297's Avatar
Originally Posted by gilwilliams101 View Post
Our Puma Unleashed black tank meter said 3/4 the day it was brand new. (last July)
Last weekend someone visiting flushed several tampons and stopped up the .... tank.
Garden hose IN the toilet, let the tank completely fill 4 times and completely dump 4 times and now the black tank gauge works as designed!!! We have a factory installed black tank flush that has never helped the sensor issue.
Might be worth a try!
IF your shower head is as close to the toilet as ours (and you have a lot of patience), one could fill the tank through the toilet with the shower head if they so desired.......... Being a toy hauler, I simply drug the hose in through the garage to do the deed.
So, he should put a few tampons in the tank?
Bruce
Old 06-05-2016, 07:16 PM   #24
Who Dares, Wins
doc73's Avatar
Originally Posted by OldCoot View Post
Install a Blue Streak and use 50-50 mix of Super Clean and water in it. Solves the problem.
Chemical Dispensing Systems for RV & Marine | Blue Streak LLC
On a side note.. I think you MIGHT have been using Pine Sol and Water or similar and it jelled up some time ago (in another thread). Ever figure out why or if it was just getting old and separating?
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 06-05-2016, 07:21 PM   #25
I have a similar mixture sitting on a shelf waiting to see if it jells like it did in the Blue Streak. Been sitting on the shelf for about 7 weeks and it has not jelled yet.
Old 06-05-2016, 07:25 PM   #26
Whiteknight's Avatar
I have used this gadget on 4 different trailers now and seldom had problems with any of the tank sensors giving a false reading afterwards. I install them in both the black and grey tanks were the nozzle is spraying directly on the tank sensors to rinse them off. It's called Camco Quickie Flush. I test the spray pattern first before installing and drill a couple larger holes to spray toward the sensors.
2012 Flagstaff V-Lite 30WFKSS
2015 Ram 2500 Big Horn Mega Cab 4X4
Whiteknight is offline   Reply With Quote
Old 06-05-2016, 07:46 PM   #27
Who Dares, Wins
doc73's Avatar
Ok thanks.
2015 ChevyHD D-Max
Old 06-05-2016, 08:05 PM   #28
dcheatwood's Avatar
Does your shower head reach your toilet? If so, fill the tank with hot, soapy water from the shower, let sit a while then drain.
Maybe hot water can dissolve hardened waste, if that's the problem. Good luck.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 06-05-2016, 08:31 PM   #29
Bruce
Heck NO!!!
That's what started the whole mess and the happy ending was my sensors started working right for the first time.
Trust me, I was just fine with the fact that the sensors did not work! LOL
I feel like a real tool putting a sign in the bathroom stating NO tampons in the toilet, but I am NOT going through that ordeal again!!! LOL
gilwilliams101 is offline   Reply With Quote
Old 06-06-2016, 12:17 AM   #30
the Quickie Flush does a great job, I've installed 4, two gray tanks and two black tanks, on two previous tt,..... I actually have two more hanging in my garage, bought to install on our present trailer, Micro Lite 25KS,..... I bought them before the trailer, not knowing that it would come with a factory installed flush unit and when I was informed(and then verified) that the factory flush unit was mounted on the drain side, which IMO is the wrong side, I was preparing to install one on the opposite side of the black tank,..... but , first did a test and discovered that the factory unit does clean well if used in a certain way(see post #22),...... IMO any tank without a factory flush unit should have a Quickie Flush installed.....................
black tank, tank, black
