Old 05-02-2015, 09:53 AM   #1
kevinstennes's Avatar
dealer gripe
Upon hooking my trailer to live water for the first time yesterday, I noticed water spraying back out from the water inlet and also water draining down the supply line hoses inside the trailer. I removed the 3 screws (which had visibly been removed before), cut the sealant, and pulled the assembly out of the trailer wall. The back side of the water inlet had been stuffed with plumber's putty and re-installed at the dealer (Poulsbo RV). I noticed that there was no gasket in the hose bib, so I put in a $.25 gasket, reinstalled the water inlet and problem appears to be solved. I'm hoping this is a case of idiocy at the dealer and not a cover-up of something larger. I have already had my share of problems with the unit and hope to be moving forward with more positives! To be fair, Poulsbo RV did replace/repair the converter, microwave and fridge electrical lines and all seems to be working great.
kevinstennes is offline   Reply With Quote
Old 05-02-2015, 09:59 AM   #2
Ford Idaho's Avatar
Lightbulb
It did not help the rabbit much but perhaps it will work for you.
Old 05-02-2015, 10:01 AM   #3
Thanks for the good luck! I think that some of my issues have been normal in getting a new unit set up and ready to use and some have been back luck. But looking forward to our first outing next week.
dealer
