Old 10-23-2013, 01:54 PM   #1
Guest
Device on water pump
My last trailer didn't have this, but it is a clear piece, attached at the inlet side of the pump. I think it's the water filter. Do I need to do anything special for it when I winterize?
John4th is offline   Reply With Quote
Old 10-23-2013, 02:25 PM   #2
B47
A pic or two would be helpful.
Is the piece round? If it is like mine, it's a filter housing and mine came loose once and started leaking and I tracked it down to the housing coming loose and leaking.
B47 is online now   Reply With Quote
Old 10-23-2013, 02:33 PM   #3
fonzie's Avatar
It is a coarse filter to inlet of water pump. You can unscrew cap and clean it, then re-install and your good to go winterizing.
Name:	Water pump winterization kit 1 before.jpg
Fonzie
Old 10-23-2013, 02:36 PM   #4
If its small like the above pic, its a strainer, you can remove and clean and replace. If you are talking a clear plastic container about 9" long with a filter in it, you need to remove filter before you winterize.
2012 F350 Lariat CC SRW 6.7L Powerstroke
pwrstroke2012 is offline   Reply With Quote
Old 10-23-2013, 03:05 PM   #5
Guest
It's the small one in the pic. After I clean it then it's fine to shoot the anti freeze through it?
Old 10-23-2013, 03:08 PM   #6
fonzie's Avatar
Yes you got it......
Fonzie
Old 10-23-2013, 03:44 PM   #7
Brother Les's Avatar
If you live in a freeze zone, get the water out of the filter bowl and/or put anti-freeze in it or it may/will crack the plastic bowl. (It only happened to me once )
Brother Les
pump, water, water pump
