Old 05-09-2013, 09:19 PM   #21
caper's Avatar
Is there water in the fresh water tank? If you filled the HW tank with water from the fresh water tank, you could be o0ut of water. I know you said the fresh tank was full. Did you actually see the water in the tank? If your pump is not shutting off, it must not be getting water.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 05-09-2013, 09:19 PM   #22
Yeah, but in all fairness- Vince's answer was a heck of a lot more descriptive than mine. I was all like, "yeah, flip some valves or something" and Vince was like, "here's exactly what you're looking for"! :-)
Post # 3 was mine and said(Check where it was broke to Winterize). Youroo!!
Old 05-09-2013, 09:47 PM   #23
Berkshire 390QS
NO3putt's Avatar
Have a great trip.
Old 05-09-2013, 09:48 PM   #24
PineForestCamper's Avatar
Originally Posted by youroo View Post
Sounds like a suction side of pump leak. Check where you broke the connection to winterize? Youroo!!
Ohhhh. Reread this thing again. The first time I read it I literally thought I was reading a riddle but it makes sense now. Kinda like how instructions make sense "after" you get something put together.
2009 Chevy Silverado/2500/6.0/3.73/CC
2016 Keystone Outback 250URS
2013 Rockwood Roo 233s (SOLD)
http://instagram.com/pineforestcamper#
PineForestCamper is offline   Reply With Quote
Old 05-10-2013, 02:34 AM   #25
Rebel702's Avatar
Just to note, when you are hooked to city water you do not need to run the pump. Pressure is supplied by the city hook-up. If you run the pump you are pulling from your fresh water tank.
When you were running the pump w/ the city water the pump would stop because the lines were pressurized by the outside connection.
Rockwood Windjammer 3002W (11/10/2011)
2011 Sierra Denali HD - Duramax/Allison
EQ-4, 14,000/1,400
2006 Yukon Denali
Rebel702 is offline   Reply With Quote
Old 05-10-2013, 02:38 AM   #26
Rebel702's Avatar
Be sure to also check the bypass valves on you waterheater. Since you did not do the winterization you should check these also.
See this thread: Water heater bypass
EQ-4, 14,000/1,400
2006 Yukon Denali
Old 05-10-2013, 02:31 PM   #27
Good information. Water heater is filled and I warmed her up via propane. I do have a question about the electric switch. When I turn that on do I have to have the hot water heater switch on for it to heat water via electricity? Can I have both on? Just curious. By hot water switch I mean the one inside the camper.
Old 05-10-2013, 02:44 PM   #28
TURBS's Avatar
You can run both at the same time or one or the other.
If you have both the gas and electric switch on the inside of camper then the switch on the outside must be on to use the electric switch on the inside.
Old 05-10-2013, 02:53 PM   #29
Herk7769's Avatar
My money is here...
HAM CALLSIGN - KC3FFW
Old 05-10-2013, 03:34 PM   #30
Okay..Mr Overkill here....
I have only one inside switch and one outside. Make any corrections to my analysis.
--> Inside ON / Outside OFF
Runs on Propane Only
--> Inside OFF / Outside ON
Runs on Electric Only
--> Inside ON / Outside ON
Runs on Propane If Not Hooked To Power.
Runs on Electric If Hooked to Power
--> Inside OFF / Outside OFF
The Flame Is Out
In my pictures I have Inside ON / Outside OFF which means it will run on propane only.
ID:	30069   Click image for larger version
