Old 05-10-2013, 03:41 PM   #31
TURBS's Avatar
Originally Posted by WarMovies View Post
Okay..Mr Overkill here....
I have only one inside switch and one outside. Make any corrections to my analysis.
--> Inside ON / Outside OFF
Runs on Propane Only
--> Inside OFF / Outside ON
Runs on Electric Only
--> Inside ON / Outside ON
Runs on Propane If Not Hooked To Power.
Runs on Electric If Hooked to Power
--> Inside OFF / Outside OFF
The Flame Is Out
In my pictures I have Inside ON / Outside OFF which means it will run on propane only.
Nailed it!
If hooked to shore power and both switches are on both gas and electric will work.
Its not like your fridge Whereas it defaults to electric if shore power is on.
Old 05-10-2013, 03:42 PM   #32
About the only other thing to add- never ever run your water heater without water in the tank. Always verify it has water by checking the pressure relief valve.
2013 Sabre 36QBOK pulled by a 2012 Ram 3500 DRW
Blogs: Learn to RV & Personal Fulltiming Adventure
Towing Calculators: Towing Planner
ependydad is online now   Reply With Quote
Old 05-11-2013, 08:26 AM   #33
Jbadams's Avatar
Thanks you'll for your post. I will be de-winterizing my RV soon as it stop raining. It help me and I haven't started yet. It gave things to look for. Thanks everyone for sharing there knowledge.
Jbadams is offline   Reply With Quote
