Old 03-18-2019, 12:36 PM   #1
MDK
Dewinterizing when you can't do it at home
Hello! I'm a new RVer and am hoping for some suggestions as to where to dewinterize if it can't be done in one's driveway/at home. I'm in NW VA.
It seems like a kind of daunting process...
MDK is offline   Reply With Quote
Old 03-18-2019, 12:58 PM   #2
Kasual Kamper
Maybe explain what your concerns are? Are you worried about flushing the water system? Any place where you can attach a garden hose and fill the hot water tank should do it.
To de-winterize, you just need to flush the anti-freeze out of the system with fresh water. It can just go into your holding tank until you're someplace where you can dump it.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is online now   Reply With Quote
Old 03-18-2019, 01:22 PM   #3
Mr Towed's Avatar
Exactly, if you just let it all drain to the tanks there won't be anything hitting the ground if that's what you are worried about.
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Cats: Rhody and Hazy
Mr Towed is offline   Reply With Quote
Old 03-18-2019, 01:29 PM   #4
MT Biker's Avatar
RV anti-freeze is Non-toxic
https://www.facebook.com/westshorerailway/
2019 Ford F-250 Super Cab 6.2L Lariat
2016 ML23FB
MT Biker is offline   Reply With Quote
Old 03-18-2019, 01:39 PM   #5
kenandterry's Avatar
We all did it for the first time once. There’s nothing to it, but here’s a step by step.
https://www.coach-net.com/emails/con...eck%20List.pdf
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
Old 03-19-2019, 01:07 PM   #6
rockfossilman's Avatar
Bit it will kill the grass in your lawn--I learned this the hard way🙄.
rockfossilman is offline   Reply With Quote
Old 03-19-2019, 01:41 PM   #7
Is it toxic to Fido or Felix?
2010 Nissan Frontier Crew Cab long bed 2WD
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 03-19-2019, 02:43 PM   #8
I usually check in to a nearby campground with full hookups for 1 night. Don't really need to do that just to flush the antifreeze. (As others have pointed out, you can flush the anti-freeze into your holding tanks.) However I also sanitize the water system at the same time. That involves filling (and emptying) your freshwater tank twice (first time with bleach added). You really need the sewer hookup for that part. This is also a good opportunity to do a pre-season "shakedown" and make sure everything is working.
2018 Grand Design Imagine 2600RB
2019 Chevy Silverado 2500HD 4x4 LT Crew Cab, Vortec 6L V8, 4.10 Rear Axle
Equal-i-zer 1,200/12,000# Hitch
Mark Ulmer is offline   Reply With Quote
Old 03-19-2019, 02:57 PM   #9
Same here. We’re booked at a full services campground less than an hour away with 50amp service. I flush and empty all the tanks and system several times, turn on and run as many appliances and features as I can to “wake everybody” up from their winter nap. I’d rather know everything tests ok on a shake down camping weekend rather than the first one of the season that matters.
Then....... bring on camping season!!!
Ken and Terry
Old 03-19-2019, 02:57 PM   #10
Flybob's Avatar
Use an empty jug and open the Low point drains and a faucet and drain the antifreeze into the jug and take it to a local antifreeze recycling station. Odds are it is less than 3 gals.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
winter
