12-10-2013, 07:15 AM
Did I ruin my water pump?
I went dry camping a few weeks back, which was just a few weeks after having my camper winterized. I heard this low pitch hum but mostly when I was laying on the bed at the front of the camper. After about a day and a half I finally realized the water pump was on. I have never used the pump so never thought to check it. Apparently when the camper was winterized, the camper lot left the switch on. So can running the pump dry ruin it? How much is a new pump?
2021 Micro Lite 25FKBS
2021 Ford F-250 XLT CCSB 4wd w/ 6.2l and 6 sp. transmission, 3.73 locking axle
12-10-2013, 07:31 AM
Lots of people run them dry by mistake without damage. You enjoy your unit and have a good time. PS pump is under 75.00$ Youroo!!
It's probably OK.
I left mine on once for several hours by accident and it still works ....3 years
or so later.
The only way to know for sure is test it with real water next spring but my
guess is you're -probably- ok.
Good Luck!
Peace!
Dan & Rita D
12-10-2013, 07:46 AM
Your water pump should be fine but if it isn’t, new pumps aren’t too expensive. Just Google “RV water pumps” and you’ll get an idea of cost. They’re easy to install unless your pump is located in a very tight out of the way location.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
12-10-2013, 07:51 AM
I've seen bilge pumps left running on boats and run dry for weeks at a time without damaging them, so you are probably OK. You did say that a camper place winterized your unit? I might tell them what you discovered, just to put them on notice, just in case. At the very least, it might cause their techs to double-check that everything is off after finishing any service work.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2021 Chevy Silverado 3500HD DRW 4X4 Duramax
“It's not how old you are, it's how you are old.” ― Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
12-10-2013, 08:03 AM
Left mine on for over a week by mistake 3 years ago. It still works fine.
2012 F350 Lariat CC SRW 6.7L Powerstroke
12-10-2013, 09:50 AM
Thanks for the info everyone. Have a Merry Christmas and Happy New Year!
12-10-2013, 09:56 AM
One other thing,most W/Pump switchs have a (Blue Illuminated) light that is On when pump is activated! If not consider changing the pump switch. Just a though. Youroo!!
12-10-2013, 12:22 PM
It does have the blue lighted switch, just not something I was use to noticing.
12-10-2013, 01:03 PM
Others have had good luck from having them run dry. I on the other hand have toasted 2 pumps from just a couple hours of dry running.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
12-10-2013, 06:48 PM
Aquaman,your pumps were (Sump Pumps) also I have never known you to run(DRY)! Youroo!!
12-10-2013, 07:57 PM
I wondered how long that was going to take. lol. And you're absolutely right.
