Old 04-30-2017, 08:36 PM   #1
Did my Faucet Die?
A week ago the kitchen faucet slowed to a trickle then came back to life on its own. Today we noticed a leak just under the solid surface countertop. Tightened up some connections now the faucet is at a trickle again. All other faucets are normal. Did my faucet just die? Or is it repairable. If its time to replace what do I need to watch out for? Faucet is a Dura single handle with spray feature. TIA.
Prophead is offline   Reply With Quote
Old 04-30-2017, 08:50 PM   #2
crunchman12001's Avatar
Remove the spray head to check for blockage at the screen.
2015 F-250 FX4
Old 04-30-2017, 08:56 PM   #3
Gumpster808's Avatar
X2 on the screens - took ours out 2 weekends ago to de-winterize etc. and our kitchen faucet was doing the same thing.
Pullout type so had two screens - both had become clogged - cleaned with a small scrub brush - all better.
Best place to start for tracking down the issue.
2014 3051S - First RV for us
Gumpster808 is offline   Reply With Quote
Old 04-30-2017, 09:12 PM   #4
Removed spray head & still at a trickle with no spray head attached.
Old 04-30-2017, 09:18 PM   #5
SeaDog's Avatar
like others have said remove the screen and clean it let the forum know how you fixed the problem
Retired Navy
2016 Flagstaff 26 FKWS
Old 04-30-2017, 09:18 PM   #6
Spray head on mine had two screens - one in the very end of the spray head and there was another where the spray head connects to the pull out hose itself.
Sounds like you have the spray head off - make sure you keep track of how / order the pieces come out of the next section - take the items out of the end of the hose that screws up into the spray head (assuming it is similar) - should be a white plastic piece / rubber gasket and screen assembly.
Once those are out try the water again - have to make sure the hose doesn't drop back through the assembly to under the sink.
Old 04-30-2017, 09:37 PM   #7
If it was a spray head (screen) problem then shouldn't I have normal flow with it removed? My flow is down to a trickle with the spray head removed.
Old 04-30-2017, 09:41 PM   #8
Mine has two - one in the very end of the spray head and the other in the end of the connections that go into the spray head - i had to remove all and just have the hose with straight connection - then i got good flow.
Old 05-01-2017, 04:35 AM   #9
Buy a new / better faucet from Home Depot. I assume you have traced the supply lines back as far as possible to verify no kinks?
How old is your trailer / faucet?
Was it properly winterized?
2015 F-250 FX4
Old 05-01-2017, 12:27 PM   #10
TS Forums So there is 2 screens in the sprayer head good to know Bill
Big Bill is offline   Reply With Quote
Old 05-01-2017, 12:39 PM   #11
At least on mine there is. Pulled sprayer off the hose and still had trickle. Took next section back off and found another.
Both mine had gunk in them I had to clean up.
Once I tested with both sections off had great flow from the hose itself so knew I had it narrowed down as well.
Old 05-01-2017, 12:44 PM   #12
Disconnected water lines & checked flow from supply side & it was fine. Only thing left is the faucet. Went to Home Depot this morning & replaced it with a $98 model; alls well in RV land again. Thanks for all the help.
Old 05-01-2017, 12:47 PM   #13
Glad to hear all is well again.
Old 05-01-2017, 12:49 PM   #14
You probably could have pulled the cartridge (the actual faucet valve) and cleaned it and all would have been good. Often times the debris gets jammed in the cartridge and cuts off water flow.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 05-01-2017, 03:17 PM   #15
I had a similar problem one time and it was the o-ring and washer in the tap.
I small cheap repair.
Robertpaul is offline   Reply With Quote
Old 05-02-2017, 11:43 AM   #16
Did my Faucet Die
Check the cartridge under the sink. I bet like mine it was clogged with those little white calcium chunks.
jhcalverley is offline   Reply With Quote
faucet
