Old 07-20-2014, 02:23 PM   #1
BandJCarm's Avatar
Do I do what Flowdown suggests?
First year camper. Learning each time.
Had a site with sewer last time, getting another site in 2 weeks. Had an issue with droopy hose, so got the "Flowdown" sewer trough. Seems to be a good product, haven't used it yet.
The instructions say that I should NEVER open the sewer/blackwater valve when connected to site sewer.....that I should always leave both gray and black valves closed, then periodically go out and dump both one at a time, same as I would at a dump station. It says that opening the black water valve while using it will damage it somehow.
Maybe this is obvious (roll eyes here, if it is.....), but is that correct? The few times we've had sewer connection, we just left valve open and flushed.
Which is correct??
BandJCarm is offline   Reply With Quote
Old 07-20-2014, 02:27 PM   #2
NELA
Weezer's Avatar
Flowdown is correct. As others will tell you, if you leave the black valve open you'll end up with a small mountain of dry "stuff" in the black tank right under where the toilet "deposits" it. You need to allow a "soup" to form.
Dump the black tank first, then the grey and/or galley tanks.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 07-20-2014, 02:32 PM   #3
pvillebly's Avatar
If you leave the valves open, the liquids will flow from the tanks and the solids will remain in the tanks with no liquids to break them down. Solids gathering in the black tank are often referred to as "the pyramid of death". Follow the directions and leave the valves closed.
pvillebly is offline   Reply With Quote
Old 07-20-2014, 02:39 PM   #4
Ford Idaho's Avatar
You need flow, no water, no flow.
I let the black tank get about 3/4 full and then dump and then flush close the valve dump the gray, close the valve run the black tank flush with the valve open for about 5 min.
Close the black, add tank treatment and some water, done.
Old 07-20-2014, 02:53 PM   #5
LouNick's Avatar
If you leave the dump valve open, your black tank is not only collecting solids, but it is sharing sewer gas with the public sewer system. Each flush, some of that sewer gas will be pulled into your rig, especially if your toilet exhaust fan is on during the flush. Keeping it closed with your favorite black tank treatment/deodorizer in it will be much more pleasant.
Lou and Paula
2014 Rockwood 8289WS UltraLite w/Revolution Pinbox Engaged.
2011 F250 Power Stroke Super Duty King Ranch Super Crew Cab w/Reese 16K Hitch
Lou & Paula
2014 Rockwood 8289WS Ultra Lite w/Reese Revloution Pinbox.
2011 F250 Power Stroke Super Duty King Ranch Super Crew w/Reese 16k Fixed Hitch
LouNick is offline   Reply With Quote
Old 07-20-2014, 02:55 PM   #6
BandJCarm's Avatar
Clearly, this was a dumb novice question! Thanks guys! Duh! I just figured if I was connected to sewer, I'd leave it open and flush and be 'done' with it.
Not so.
I do appreciate the info. Roll eyes at will (I'm Will)!!!!
Old 07-20-2014, 02:59 PM   #7
NELA
Weezer's Avatar
We all started somewhere Will. this is the first time I felt confident enough to be the first to answer such a question.
I often say: I knew RVing would involve a learning curve, just didn't know there would be more than one S curve.
Old 07-20-2014, 03:01 PM   #8
Ford Idaho's Avatar
Not so.
You might find it at Walmart but I am not sure.
Amazon.com: RID-X RV Toilet Treatment Liquid, 16 Treatments, 48 Ounce: Health & Personal Care
Follow the directions to get rid of any "build up" you may have in the black tank.
Old 07-20-2014, 03:06 PM   #9
BandJCarm's Avatar
I've learned more about RV TV than most.............but it seems that's the ONLY thing I know about these money pits!!
Thanks again.
Old 07-20-2014, 03:07 PM   #10
NELA
Weezer's Avatar
Also do a search on the forum for the use of ice plus water then drive on the highway method of scrubbing the black tank and/or cleaning off the tank sensors.
