Old 01-15-2009, 05:26 PM   #1
Do I need to caulk the shower?
Hi.
We just picked up this used 07 27 bunk house... I've noticed the shower wall panels are not caulked where they meet the tub... yeah, I'm guessing they have caulk behind them, but I'm thinking it should be done on the face as well.
your thoughts?
Perry Brown
pbrox is offline   Reply With Quote
Old 01-15-2009, 05:44 PM   #2
I wouldn't worry about it
the caulking might end up tearing the wallpaper from the movement while the rig is in motion
aintgotnun is offline   Reply With Quote
Old 01-15-2009, 05:52 PM   #3
Yeah.. I knew I worded it wrong... The shower panels come down the wall and then meet the tub unit... essentially it's a 2 piece unit.. So it's not caulked where the wall panels meet the tub unit... hope that makes sense...
Old 01-15-2009, 06:00 PM   #4
Commercial Member
huntr70's Avatar
They are not caulked for a reason............there is a flange from the shower pan behind them, and they leave it open to make any moisture that may get back there evaporate.
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
huntr70 is offline   Reply With Quote
Old 01-16-2009, 05:57 AM   #5
cardinal4fun's Avatar
I would not caulk the bottom as stated before. The reason is if you do caulk and water gets behind the panels there would be no way for it to exit. I would check the caulk around the faucet.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
Old 01-16-2009, 06:31 AM   #6
Grape Escape
Water should not get behind the panels in the first place. Had to caulk every joint in the shower to stop it from leaking out.
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 01-16-2009, 11:38 AM   #7
Send a message via Yahoo to SSport
mine was not caulke and leaked very bad. after it was caulked....no leaks
2008 Cherokee 39BS
SSport is offline   Reply With Quote
Old 01-16-2009, 12:58 PM   #8
I calked all edges and joints of the shower suround and folding door frame. No problems afterwords.
out4stlhed is offline   Reply With Quote
Old 01-16-2009, 06:59 PM   #9
Commercial Member
huntr70's Avatar
To each his own............I've seen wallboards rotted out from moisture back there.
My 'Cat leaked through the faucet........
Steve and Vicki
2 kids
(Tweaked!!)
Old 01-21-2009, 08:33 AM   #10
Caulk only where you want to prevent water and moisture from getting IN, not OUT. Do not caulk the wall panels because you want air to get in there and evaporate any residual moisture. Ocassionally place a portable fan in the bathroom doorway and let it run for a day or so when the trailer is not in use. This will help circulate the air and dry things out. You will not get liquid water in behind the panels because water cannot run uphill. You DO want to caulk around the tub/shower fixture at the floor to prevent water from getting into the sub floor. You might also want to fill in any spaces around the water lines or other openings with expandable foam. I have gone through my trailer hunting down any opening that would let cold air or water in from the outside and filled them in with expandable foam like 'Great Stuff'. This includes getting underneath the trailer and filling in where the water and electric lines come up through the floor. You will be amazed at what you find when you go looking 'behind the scenes'. It certainly has made a difference in the invasion of cold air and moisture from the outside.
Facory is offline   Reply With Quote
