08-16-2019, 11:49 PM
#61
I always let the hose run for awhile to rinse it out. No point putting air into the system.
08-17-2019, 06:53 AM
#62
Originally Posted by 007matman
I always run a bit of water throu the hose prior to connecting to the camper to flush out any contaminated water or bugs that may have gotten in there.
I've never seen that air is a problem so I'm not as concerned with that.
Ditto
08-17-2019, 07:46 AM
#63
Can you run 3800 fps?
Always! Keeps out the debris and critters.
08-17-2019, 08:57 AM
#64
I have learned to carry a clean white bucket with me. Before I hook any water supply to my camper, I run a bucket full of water to see what it looks like. Sometimes the water quality is so poor that I don't even want to wash with it, much less make coffee with it.
We once stayed at a small family owned campground near Piqua, Ohio and the water was so bad that it clogged my whole house filter in three days. The filter looked as if it had been dipped in red paint.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
08-19-2019, 10:34 AM
#65
I use a shut off valve on the end of the hose to bleed air before I connect to the RV. No sense in adding stagnant water from hose and air into the water system. Purge only takes a half minute.
John
2019 Ram 3500 CC 4X4 Cummins 6.7l
2020 Fuzion 369 toy hauler
08-19-2019, 02:42 PM
#66
I always flush out my drinking hose before attaching it... clears out anything that has gotten into the hose since last use, and also clears out anything that was in the campsite water line just before the water valve. In addition you are purging as much air out of the line rather than sending it into your camper where the faucet, toilet, shower will hiss, sputter and spit for a few seconds while the air is purged from the lines you introduced. Doesn't really hurt anything that I can tell and I don't believe it is a wrong or right thing, just choice and preference. Just like us... there is always my way and their way, and someone has to give!
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
08-22-2019, 06:22 PM
#67
Originally Posted by smgelsie
My husband and I are having a "disagreement "....when I connect the water hose to a park's water supply, I start at the source, turn the water on to fill the hose, and then connect the "primed" hose to our trailer. I don't like all of that air in my lines in the trailer! My honey says nobody does that! Can I get a vote???
I turn on the campsite spickot, then connect the hose turn the water back on to flush out the hose, then connect to RV. Flushing is my objective.
Cheers, Jim and Sandy
'14 F150 FX4, '15 Coachmen FE29SE
08-22-2019, 06:36 PM
#68
Nope ... never. Simply open a hot and cold faucet inside and purge through there, especially the hot water side.
Also, when I disconnect the water hose, I drain it, coil it up, and connect the ends to keep contaminants out.
08-22-2019, 06:47 PM
#69
Originally Posted by gl1800rider
do it every time. No sense in introducing a bunch of air into the system causing water hammer. The plumbing gets enough shaking going down our wonderful highway system.
x2 🤔
08-22-2019, 06:51 PM
#70
The Dude Abides
Seems like a no brainer to get the air out before hooking up.
08-22-2019, 07:08 PM
#71
I prime every time, not only to prevent a hose full of air in the system, but also to flush the hose a little before hooking to the RV.
08-22-2019, 07:11 PM
#72
My preferred method always.
08-22-2019, 07:14 PM
#73
I have a valved Y adapter at the RV end of the hose. I turn both valves off then open the hose connection on the other end and pressurize the hose. I then open the valve on the open side of the Y adapter and purge the air out of the hose. I then close that valve and then open the one into the water filter that's connected to the other side of the Y adapter and the RV. I'll still get a little air from the filter but not nearly as much as if I didn't purge the hose. Also, I have a pressure regulator on the inlet side of the Y adapter. It works great.
08-22-2019, 07:21 PM
#74
I agree with Retiree and I add one step: I run the water from the source to visually check for sediment and rust BEFORE connecting my hose. When it runs clear, I connect and flush / prime the hose. Then I connect the hose to the trailer and turn on my shut off valve SLOWLY while listening to hear if there is water running (indicating a plumbing leak / fault) . I have been doing that for years.
08-22-2019, 07:23 PM
#75
I always run a couple gallons through the hose & then the filter before connecting to the rig. Never know what's in the line or hoses. Also cools off the hose & filter. I put a Y connector at the park spigot, at the end of the hose to facilitate flushing, connection of black water flush hose, rinsing out/freshening pet water bowl, etc.
2016 Ram 3500 Cummins Aisin 3.42 axle SRW LB CC pucks auto level 25 gal aux fuel tank towing 2016 Primetime Crusader 315RST Trailer Blocks, Lippert Correct Trac added, Goodyear Endurance tires Hawkshead TPM Good Sams GPS/trip planner
Days Camped: 2016 - 17: 2017 - 24: 2018 - 86: 2019 - 82
08-22-2019, 07:47 PM
#76
I do it every time!
08-22-2019, 07:49 PM
#77
I do. Have hose valves and caps and plugs to hold water and keep ends clean. Hate the sputtering. Also, since I often pull water from a tank in my tow vehicle (with the pump in the RV), keeping the hose full avoids the need to prime the system.
08-22-2019, 08:07 PM
#78
I have never done it and it may not be neccessary, but I think it is a good idea and I will do it from now on. Thanks for the idea!
08-22-2019, 08:51 PM
#79
I do the same but not for the same reason. I want to make sure no debris from the spigot or hose gets into the RV.
2006 Georgetown 340 TS
08-22-2019, 09:00 PM
#80
Yes & No. I have a T which the filter and hose connect to the trailer.I has a faucet attached to it which I leave open to bleed off any air. It also lets me bleed the pressure off before disconnecting.
"There comes a time in every man's life, and I've seen plenty of them." Casey Stengel
"Red" my 2018 Ford Lariat F-150 4X4 W/ Max Tow pkg
"Rover" our 2018 Forest River Wildwood X-Lite 241qbxl
