Old 08-15-2019, 12:51 PM   #1
Do You Prime Your Water Hose
My husband and I are having a "disagreement "....when I connect the water hose to a park's water supply, I start at the source, turn the water on to fill the hose, and then connect the "primed" hose to our trailer. I don't like all of that air in my lines in the trailer! My honey says nobody does that! Can I get a vote???
smgelsie is offline   Reply With Quote
Old 08-15-2019, 12:58 PM   #2
Citrus County, Fl.
GL1800Rider's Avatar
Do it every time. No sense in introducing a bunch of air into the system causing water hammer. The plumbing gets enough shaking going down our wonderful highway system.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is online now   Reply With Quote
Old 08-15-2019, 01:01 PM   #3
jd50i's Avatar
Nope, I don't do it.
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
jd50i is offline   Reply With Quote
Old 08-15-2019, 01:18 PM   #4
retiree's Avatar
I have a shut off on the end that connects to the TT. I always prime, shut it off and then connect and reopen. No need for all that air in the system, especially if you happen to use hot water first and get it in the HW tank.
Turning Miles Into Memories
Visit my Blog at https://rv-memories.blogspot.com/
2020 Apex Ultra Lite 215RBK
retiree is offline   Reply With Quote
Old 08-15-2019, 01:24 PM   #5
saus's Avatar
I do. I have my wife open the faucets. Then I turn on the water.
2016 Forest River Wildcat 314BHX
2019 Ford F-450 Limited DRW 6.7 Diesel
saus is offline   Reply With Quote
Old 08-15-2019, 01:33 PM   #6
I will have to try that next trip. I always have a shutoff valve at the camper inlet.
2019 ROO 233S
2017 Dodge Ram 1500 Laramie
Wisconsin-1 is online now   Reply With Quote
Old 08-15-2019, 01:56 PM   #7
Sometimes I do, and sometimes I don't. I think it has to do with the "tired" factor. Doesn't bother me either way. I can tell you though, my wife HATES it when I don't and doesn't hesitate to mention it to me...
Jdedgewood is offline   Reply With Quote
Old 08-15-2019, 02:06 PM   #8
YEP ! do the same thing. Keep hose in a sealed bag but figure water will push anything out that may have gotten in to it.
TheWolfPaq82 is offline   Reply With Quote
Old 08-15-2019, 02:09 PM   #9
007matman's Avatar
I always run a bit of water throu the hose prior to connecting to the camper to flush out any contaminated water or bugs that may have gotten in there.
I've never seen that air is a problem so I'm not as concerned with that.
007matman is online now   Reply With Quote
Old 08-15-2019, 02:27 PM   #10
Fulltime family RVer
Never intentionally. We do it sometimes just in the order of hook go up utilities. But not because I’m trying to specifically prime the hose.
I find we get sputtering at the faucets inside the camper no matter if I prime it or not.
Old 08-15-2019, 02:28 PM   #11
llr
X2
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 08-15-2019, 02:30 PM   #12
Oaklevel's Avatar
My wife has no idea what I do she works inside I connect up the outside................
Do I prime the water hose to prime the water hose no way............. but I do run water through the hose to wash out anything that could had grown inside it.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 08-15-2019, 02:34 PM   #13
A32Deuce's Avatar
All the time. I have an outside faucet with a T for the city water connection. Open then turn on city water and close when I get there. Gets fresh water into the unit and the funky water on the ground rather then in my unit lines. Stale, rusty, sediments, etc.
Also use to relieve pressure before disconnecting city water and/or fill FWT.
A32Deuce is offline   Reply With Quote
Old 08-15-2019, 02:43 PM   #14
Bingo! I've seen dark water come out of the hose end from a spigot that evidently hadn't been used in quite awhile. I always flush a gallon or two through the hose first.
woo10-210 is offline   Reply With Quote
Old 08-15-2019, 02:45 PM   #15
I hook to CG water... Run hose out for 30 secs or so to rinse out. Hook up to city water connection (with filter and pressure regulator); open a couple of faucets; Hot and cold; turn on CG water and let it run for a couple of minutes just to turn over the water in the lines thats been sitting. No "priming" the hose. never really have seen a need or had a problem with air other than first use after winterizing. .... which I do with air blow out and not antifreeze.
gbaldwin is offline   Reply With Quote
Old 08-15-2019, 02:46 PM   #16
bikendan's Avatar
No
Equalizer WDH
Old 08-15-2019, 03:06 PM   #17
Gold Tee Box
Teetime's Avatar
Never have, but now that you have planted that seed in my head...
Success is hiring someone to mow your lawn so you can play golf for exercise.
2018 GMC 2500 Duramax Denali
2018 Coachman Freedom Express 287BHDS
60+ campgrounds/400+ nights, 20K+ Miles towing since 2015
Teetime is offline   Reply With Quote
Old 08-15-2019, 03:23 PM   #18
NMWildcat's Avatar
X2. I run the hose just a tad to ensure clear water comes out, then hook it up to the RV. Neither of us cares about air in the lines or the second or two of spurts it causes when you turn on a faucet.
Just not a thing we care to worry about
Scott and Liz - Southern NM
Old 08-15-2019, 03:35 PM   #19
Enjoying Life
I never thought of it as priming but I guess I do. Run water to make sure nothing in it from previous use.
2019 Rockwood 2608BSD 2019 F250 4x4 6.2
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!” - Hunter S. Thompson, The Proud Highway: Saga of a Desperate Southern Gentleman, 1955-1967
TeachTexas is online now   Reply With Quote
Old 08-15-2019, 03:42 PM   #20
RV There Yet?
IsleDog's Avatar
We use the expanding hoses and have a shutoff valve on the end. Flush the line, close the shutoff on the end, hose expands and is then connected to the camper. when we leave for the day, we can quickly turn off the shutoff. always flush your lines, takes only seconds. I dont worry about the air and water hammer happening.
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
IsleDog is online now   Reply With Quote
water
