Old 09-23-2013, 10:49 AM   #11
rotorhead1250's Avatar
I think its a great idea. If he blows out the lines first, then there is no water in there, just antifreeze. All it takes is time to recover the antifreeze in the spring. I'm in!
Matt & Kathie
2017 Grey Wolf 27RR
rotorhead1250 is offline   Reply With Quote
Old 09-23-2013, 11:11 AM   #12
Triguy's Avatar
RV antifreeze is just a diluted mix of Propylene glycol and water. Camco says their Freeze Ban 50 Antifreeze is about 35% Propylene glycol. Its completely soluble in water according to the MSDS so it won't separate but it IS already a pre-diluted solution that is designed to be used full strength. According to CAMCO, "additional water dramatically alters the expansion properties of the propylene glycol solution making adequate burst protection difficult to achieve".
How much dilution would cause a problem? I know there are charts that show it but can't find one right now. I would guess there would be very little dilution when the lines are first blown out and then AF is run through. I like this method personally, but I don't reuse it the next year. Just discard and buy more in the fall. The cost isn't an issue but having one more thing to store is (for me).
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 09-23-2013, 07:37 PM   #13
Jimmerinwi's Avatar
If he's blowing out the lines to begin with, why pump it through the lines. Other than using it in the traps, it seems like a waste. If he's "frugal" he's wasting money to pump it into the lines. I blow my lines out and pink the traps and have never had an issue.
Some days I wake "Grumpy", Some days I just let her sleep......(Ray Scott)
Jimmerinwi is offline   Reply With Quote
Old 09-23-2013, 07:49 PM   #14
Originally Posted by Rugged Brown View Post
Frugal ... Yes, but there's a difference between scratching your a** and tearing it to bits.
Now that's funny....
grayfox is offline   Reply With Quote
Old 09-23-2013, 08:09 PM   #15
lswartz's Avatar
You pump it through the lines because blowing them out doesn't get all of the water. There will be some that drains to the lowest point & freezes. In my case it was a small part in the back of the toilet which was a real pain to get to for removal & replacement.
2013 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is offline   Reply With Quote
Old 09-23-2013, 08:30 PM   #16
Herk7769's Avatar
Originally Posted by Sargent's Fox Hole View Post
In a conversation with a friend, I learned that another friend [ a man ], reuses his RV antifreeze from year to year. In the Fall he blows out the water lines with air, and then pumps antifreeze through the system.
Then when Spring comes, he blows out the lines and puts the antifreeze, back into the gallon containers!!!!
Am I missing something, or is this a safe procedure????
I would never re-use RV antifreeze.
It has between 20% - 40% (depending on brand) propylene glycol dissolved in water as an anti-freeze solution. It evaporates over time from non-sealed containers and can support bacteria growth in warm weather.
MSDS PRESTONE RV ANTIFREEZE
HAM CALLSIGN - KC3FFW
Old 09-23-2013, 08:31 PM   #17
Phat Phrog Stunt Crew
elind's Avatar
Originally Posted by f1100turbo View Post
Weeeeell he may have to buy 3 at $4.00 ea
That's prolly the deal breaker.
One he could afford .... possibly not 3.
One could afford a dozen of BBC's for Saturday nite, but wouldn't spend $12 for fresh anti-freeze for peace of mind on a major investment.
2014 Wildcat 327ck
elind is online now   Reply With Quote
Old 09-23-2013, 09:01 PM   #18
Capt. Mike's Avatar
I just bought a couple of gallons at $2.97 Not worth my time, or the aggravation of possibly getting some contaminated or diluted anti-freeze in years 2 and beyond. Frugal is one thing, but, c'mon....really?
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
It's not how old you are, it's how you are old.Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 09-23-2013, 09:20 PM   #19
x-2
Old 09-24-2013, 09:28 AM   #20
I haven't asked my friend, Ron, why he does this, cause he's one of those guys, who thinks that the way he does things...is the best and only way to do things.
Could be frugality, laziness, or maybe he is a misguided environmentalist.....or maybe he was raised during the depression and those people don't waste anything!
Sargent's Fox Hole is offline   Reply With Quote
antifreeze
