Old 10-13-2018, 11:38 AM   #1
mikeb1073's Avatar
Does my anode bar need replacing?
Hey guys. So I was winterizing my new trailer for the first time this year and when I pulled the water heater drain plug I found it was this long bar (which I later researched to find out was an anode bar). I never had this in my last trailer so have never dealt with it.
My question is pretty simple, how far gone is my anode bar? Is this bad? I'm not sure how often they need replacing, I can Google around and find info about house water heaters but the info on RV water heaters is scarce.
EDIT: I thought I was adding a picture but I guess not, trying to figure out how to put it in my album here and link to it.
EDIT 2: Here goes trying...
Thanks!
- Mike -
2018 Rockwood 2509S
2015 F150 Lariat Sport
mikeb1073 is offline   Reply With Quote
Old 10-13-2018, 11:49 AM   #2
wmtire's Avatar
Your anode rod (not bar) that you have pictured is good to go for awhile. No need to replace.
2011 Flagstaff 831 RLBSS
I hate it when people don't know the difference between ur and u'r!
Old 10-13-2018, 11:50 AM   #3
Mr. Dan's Avatar
That anode rod is as good as new. Keep on trucking... or send it to me and I’ll use it!
Welcome to the site!
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 0; booked = 14
Old 10-13-2018, 11:50 AM   #4
2012 Solera
Be careful wrt the rust on the threads. Bar still has a lot of life left.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 10-13-2018, 11:52 AM   #5
wmtire's Avatar
Since you have a Suburban water heater, these videos may help:
Suburban Water Heater Video Guides
You want to replace the anode rod when it's 75% percent or more
consumed, as per this chart
Old 10-13-2018, 02:11 PM   #6
For my own piece of mind, I replace my anode rod every year after all of the water is drained from the tank and the unit is winterized. It is then ready for the upcoming year with a now rod. I'd rather be safe than sorry.
Rmstack is offline   Reply With Quote
Old 10-13-2018, 02:22 PM   #7
I do a plumbers Teflon tape wrap around the threads. Works great.
As mentioned, there is still a lot of life left in the anode.
Cold Lake Kid is offline   Reply With Quote
Old 10-13-2018, 02:32 PM   #8
mlmay12's Avatar
Still in good shape, I always used anti-seize on the threads so it would not get stuck.
2016 Dynamax Isata 3 24FW
2016 Jeep Willys JK
Yellow Labs Jake & Casey
USN-RET/DOD-RET
mlmay12 is online now   Reply With Quote
Old 10-13-2018, 02:41 PM   #9
D W
D W's Avatar
Be careful with anti-seize compounds. Many of them are lead/graphite based. Just sayin'.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator Mods- Reprogrammed 4L80E
2016 Salem 27RKSS (Pacific Northwest Build)
D W is offline   Reply With Quote
Old 10-13-2018, 02:50 PM   #10
I'm with you. I replace it once a year when I flush the tank. They are inexpensive and, as you said, "better safe than sorry".
Edmund
VMI'62
Edmund is offline   Reply With Quote
anode
