Old 09-23-2019, 05:46 AM   #1
Dometic 310 Inlet Connection
Just purchased a 310 and trying to connect the waterline to it, I snapped off the fitting. It is a pex compression fitting. I am not finding a similar connection. I want to go to a shark bite as I added an in-line shut off. It appears like it is a 1/2" faucet type connector. Can anyone verify this? I tried a brass fitting but could not get it to stop weeping not matter how much little or a lot of Teflon tape I added. The brass fitting was just for a pipe.
KKonyha is offline   Reply With Quote
Old 09-23-2019, 10:56 AM   #2
I was really hoping that someone had the answer. We are taking off this week-end to camp.
Old 09-23-2019, 11:10 AM   #3
cboss's Avatar
A pic would help, but take it to your local plumbing store (not Lowes or Home Depot). They may be able to help.
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 669
cboss is online now   Reply With Quote
Old 09-23-2019, 12:37 PM   #4
tonyz1's Avatar
Which fitting did you break? Are you talking about the line fitting coming from floor of camper or fitting on toilet? I just looked at my 300 toilet that I replaced in my camper and the only pex fittings are on the line that runs from valve up to bowl inlet. So I'm guessing it is the floor fitting?
tonyz1 is offline   Reply With Quote
Old 09-23-2019, 12:57 PM   #5
I suspect you are looking for something like this made by SharkBite...
Available at good plumbing supply houses or online.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 09-23-2019, 01:07 PM   #6
Yes, this looks close to the fitting I need. I believe in the center of the threaded end, there should be a rubber washer to push against the tip of the male end to seal. I could not find this anywhere. It is the inlet supply. 1/2" pex to the male inlet.
Old 09-23-2019, 01:23 PM   #7
bubbles's Avatar
This is a typical washer used for coupling to installed water connections for an RV. Google "rv water connection washers".
Old 09-23-2019, 06:11 PM   #8
A faucet connection works(1/2”). Home Depot had a 1/2” pex with shut off to a 1/2” faucet that works great. It comes with a 12” braided steel line. 5 min. hook up and now have a shut off if needed.
dometic
