Old 05-10-2014, 07:42 AM   #1
Dometic 310 leaking
I have a 2014 831bhds and there is a leak in the rear of the toilet.
Looks like there is a missing part
When you flush a perfect burst odds water shoots out from the part shown below.
Any ideas??
2014 Flagstaff 831BHDS
2010 Ram 2500 Cummins 4.10s - Superchip'd
Built-in Controller
Hellwig Sway Bar 7272
Equalizer Hitch system
Long Islander is offline   Reply With Quote
Old 05-10-2014, 07:53 AM   #2
Looks like the vacuum seal part.
Does anything look missing?
Built-in Controller
Old 05-10-2014, 07:55 AM   #3
Can't add picture. Forum doesn't allow through the app.
Built-in Controller
Old 05-10-2014, 08:14 AM   #4
VinceU's Avatar
From your description sounds like a defective "vacuum breaker" which allows air in to prevent backflow if shore pressure is lost. common for them to seize in the open position, allowing water pressure out. Depending on the application you can get vac breakers in HD or Lowes for 1/2 fittings pretty cheap. May also be a inline mfg part available from Dometic or agents.
Old 05-22-2014, 07:29 AM   #5
I obtained a new vacuum breaker from Dometic and the Dane thing is happening!!!
Built-in Controller
Old 05-22-2014, 11:57 AM   #6
VinceU's Avatar
Can you post a pic?
