Old 02-23-2016, 10:13 AM   #1
Dometic 320
Has anyone installed the Dometic 320 in the FR Vibe 221RBS? If so, any problems with the install and were any additional parts required?
gen3rbc is offline   Reply With Quote
Old 02-26-2016, 04:55 PM   #2
deebarjay's Avatar
might save a changeout
why are you changing out?......got a leak? just like porcelin bowl ?
if you have a leak, the new water valves that are activated when you stand on flush pedal....are a must to get....originals were crap [no pun !!]....new redesigned ones that fit 300/310/320 dometics are a snap to replace...bought mine on ebay $27 i9ncluding shipping.
2008 F250 6.4 diesel with 50 gal aux tank towing a 2015 Rockwood 2109s Minilite.
2015 Miles and nights
10040/31
2016 miles and nights
feb. 380/7......march 540/3
deebarjay is offline   Reply With Quote
Old 02-26-2016, 09:44 PM   #3
I like the larger bowl, flush and construction! Thanks for the reply.
Old 02-26-2016, 10:19 PM   #4
bubbles's Avatar
Should have no issues swapping out. The measurement from center line of toilet opening to back wall is probably the only issue just like it would be for home toilet swap out. The flange mounting that exists should be sufficient and mounting stud orientation should be the same (comes with hardware for mounting). The water connection may require some modifying but nothing major. The Dometic internet site has the install info (required dimensions) available for viewing and/or download. The 320 flush will be the gravity type (elongated) unlike the model 310 pressure swirl (has a round bowl) I believe. Could be wrong.
Old 03-17-2016, 10:40 AM   #5
Dometic 320
I installed the 320 in our Vibe 221RBS, an exact fit with no plumbing mods. Really nice toilet!
Thanks for the reply!
Old 03-17-2016, 10:48 AM   #6
flymhi's Avatar
Looking to do the same to my unit. We need PICS!!
2015 Denali Duramax 2500
2017 Coachmen 229TBS
2010 Shamrock 21SS - sold!
flymhi is offline   Reply With Quote
dometic
