Old 06-24-2016, 03:27 PM   #1
Steelchef
cobatoma's Avatar
Angry Dometic 320 Excessive Leaking
This toilet is a replacement for the original. The brochure (and dealer) says;
"water may continue to trickle into the bowl for up to 20 minutes after flushing. If water trickle continues after 30 minutes, replace the water valve."
The intended reasoning is that a small amount of water in the bowl provides a seal against unwanted odors. The reality is that I now have to dump my tank every 6 days, instead of (formerly) nine. It's not just a pain in the petoot but costly for additional chemicals.
Does anyone else have this issue and if so, please share any info/suggestions/etc.
Home base - 2014 Cedar Creek 38CK (full load.)
Travel wagon - 1994 Phoenix/Cobra 34' motor home.
Toad - 2000 Suzuki GV.
PV - 2012 Toyota Rav 4
cobatoma is offline   Reply With Quote
Old 06-24-2016, 04:07 PM   #2
I've never seen one 'trickle' for that long. A few seconds, but not minutes.
I read the manual and sure enough it says that it can trickle for 20 minutes.
How much water is collecting on top of the ball each time?
Gotta go campin!
Old 06-24-2016, 07:18 PM   #3
Steelchef
cobatoma's Avatar
It fills the bowl about 1/3.
Haven't actually timed it. Who would do that? How would you now when it stopped?
The trickle is virtually unnoticeable, except for the results in the bowl.
Am reasonably sure that it doesn't exceed the 30 minute term required for warranty replacement of valve. Not sure if a new valve would improve the issue anyway.
dometic, leak
