Old 12-21-2014, 12:42 PM   #201
Slympicins's Avatar
Dometic 800-321-9886
diane.staman@dometic.com
Heidi.mcclain@dometic.com
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 01-08-2015, 03:14 PM   #202
Toilet Odor
We have the same problem with our Rockwood 2604WS. So far, I have not been able to solve the problem or has anyone from Rockwood or Dometic bothered to respond. The smell in our unit is most prevalent when the air is on or the fan is on in the bathroom. We even get it around our sink. Let me know if you find a solution. I will do the same.
spkrvr is offline   Reply With Quote
Old 01-08-2015, 06:11 PM   #203
Slympicins's Avatar
I would say if you have the smell around anything other than the toilet, you may have a black and grey tank issue. The older Dometic 300 has specific issues for which they claim has been resolved. I snapped a picture of the sticker on the toilet and forwarded it to Diane. She sent me a replacement the next day.
Chuck and Joanne
Old 01-28-2015, 10:04 PM   #204
ejknight's Avatar
I own a 2703WS and have the Dometic 300 toilet. After reading this entire thread i decided that I should call Diane. Monday I called and gave her the serial and Diane has a new toilet being shipped from In. and will be here by tomorrow. Best expirence yet!
Ed & Kay
2015 Ram 1500 5.7 V8
2014 Rockwood 2703WS
2020 is a BUST!
ejknight is offline   Reply With Quote
Old 01-29-2015, 05:59 AM   #205
Slympicins's Avatar
Glad you took the time to read through the thread. Lots of great information in here. When you get the new 300 it will take you about 10 minutes to replace it.
Chuck and Joanne
Old 04-21-2015, 02:55 PM   #206
joy-rick's Avatar
Joy and I took delivery on a new 2014 Rockwood 8315BSS late last fall and we were only able to camp in it twice before the end of the season.
We de-winterized and took a short trip last week in preparation for a 4 week trip in May. Unfortunately I discovered liquid seeping from the bottom of the Dometic 310 toilet. A little research on this amazing forum and I concluded that I was most likely experiencing the well-know Dometic separation issue between the ceramic bowl and the vinyl base. We are 200 miles from our selling dealer, so I decided to look at it myself.
When I removed the toilet from the floor it was immediately obvious that the toilet was defective. On the good advice of this forum i called Diane Staman at Dometic yesterday morning. She asked for the serial number of the toilet and offered to send a new unit by overnight delivery. As she promised, it arrived about an hour ago. I will install it tomorrow.
I can't heap enough praise on the invaluable resource that the users and moderators of this forum provide. Thank you, thank you, thank you!
I also cannot say enough about the customer service provided by Dometic. It's unfortunate that they are experiencing so many problems with these toilets. Hopefully they will solve their manufacturing issues going forward.
Thanks again to everyone who contributes to this forum.
Rick (K8RWG), Joy, and Daffy (the spoiled Calico cat)
2016 F250 SC LWB 4x4 6.2 3.73
Reese Dual Cam
Honda EU2000i
joy-rick is offline   Reply With Quote
Old 04-21-2015, 03:05 PM   #207
Ford Idaho's Avatar
Glad to read that Dometic was willing to take care of your issue so quick.
Old 05-26-2015, 12:42 PM   #208
Sewer odor
I have a new 2014 FR Cardinal CAF3850RL that i have had for only 2 months and for the first time i left my camper for a weekend away and sealed up my unit and had left my automatic vent in operation. When i came home the vent was running and was pulling air from the bottom of the, not so well insulated under belly, covering and the entire home smelled of sewage. I am not sure where all this is coming from for i can not find any leaks. I have viewed several post about issues with the Dometic 300's. I have a Dometic 310 toilet of which i seem to never smell anything near it. Any suggestions? Do i need to pull my toilet?
malvin65 is offline   Reply With Quote
Old 05-26-2015, 07:27 PM   #209
Malvin65,
The problem with the 300 series is that "tainted" water gets between the plastic base and the ceramic bowl. If you stick your nose by this crack and smell a strong odor of sewage, that is your problem. In my case, I could stick my head in the bowl and it smelled clean, but I nearly passed out when I took a big sniff by that crack between the bowl and base.
Also possible is that you don't have any problems and your fan was drawing air through the black and grey tanks because everything else was closed up tight. Grey tanks can smell terrible, too.
Let us know what you come up with.
2018 Surveyor 266RLDS
2017 Palomino Puma 295BHSS
2013 Jayco Eagle 324BTS
2014 Flagstaff V-Lite 30WTBS (broken and TOTALED)
2008 Surveyor SV-234 (SOLD, but not forgotten)
2016 GMC Sierra SLT 2500 Crew Cab 4x4 Duramax
smithmdsmith is offline   Reply With Quote
Old 05-26-2015, 08:32 PM   #210
Slympicins's Avatar
Sounds like your sewer tank separated somewhere underneath the Cardinal. The Dometic 310's were not subject to the same issue as the 300's. Check the under belly and I would bet the sewer line either separated or the tank cracked and there is sewage in your basement.
Chuck and Joanne
Old 05-26-2015, 11:19 PM   #211
FWIW, my original toilet was a 310. Dometic replaced it almost without question. I haven't had any odor problems since the toilet was replaced.
Old 05-27-2015, 04:58 AM   #212
Slympicins's Avatar
Wow. I had thought the 310's were bullet proof. Guess there was a bad run there for a while. Thanks for that info. Definitely helps out for future use.
Chuck and Joanne
Old 05-27-2015, 05:03 AM   #213
Old car's Avatar
We have a 310 in our 2015 Sabre and this weekend was the worst. We have odor so bad that you can't stand to be in the bathroom. I have an email out to Dometic to see what can be done.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 05-27-2015, 07:21 PM   #214
Old car's Avatar
Quick response from Diane at Dometic--replacement toilet is on the way.
Randy and Patty
Old 05-27-2015, 08:54 PM   #215
Great news. Much "relief" will be had.
Old 05-27-2015, 09:43 PM   #216
Slympicins's Avatar
Is she not the best? Dometic continues to lead the industry for customer service!!!!
Chuck and Joanne
Old 07-01-2015, 10:38 AM   #217
thestrangebrew's Avatar
I have the same foul odor issue in my 2014 Roo 233s. I just emailed Diane. It appears I'll need the serial #. Can someone tell me where this number is located? Is it on the toilet itself or in a manual?
2022 F250
2014 Rockwood Roo 233s
thestrangebrew is offline   Reply With Quote
Old 07-01-2015, 11:24 AM   #218
Strange oder
SN# is on the unit You can see it better if you pull the toilet, you will have to do that anyway. Good luck care full do not tip it. messy job
brownderby is offline   Reply With Quote
Old 07-01-2015, 11:27 AM   #219
Ford Idaho's Avatar
A flashlight and a mirror will do the trick.
Old 07-01-2015, 11:46 AM   #220
larrys2112's Avatar
My serial number was directly under where the foot pedal attaches to the toilet. I stuck my cell phone in the tight space and snapped a picture of the serial number.
2016 Rockwood Windjammer 3008W Diamond Package
2016 Toyota Tundra Double Cab 5.7L SR5 4x4
larrys2112 is offline   Reply With Quote
