Old 01-21-2014, 12:05 PM   #111
lotsip's Avatar
Originally Posted by QuietTimes View Post
First check the measurements of the two toilets. The 310 is longer and when they shipped one to me it would not fit where the 300 was. They had to ship me a 300 that they SAID was problem rectified. Lets hope.
INSTALLATION:
You can do this.... Real easy. Turn off your water and bleed the pressure. Hold a container under the water hose going into the toilet and remove connection. Extra water will drain in your container. Remove two nuts holding the toilet down. Lift straight up making sure you have a bucket in case it leaks a bit.
Put new toilet in place and reconnect. Turn water back on. Check for leaks.
Takes 15 minutes to 30 minutes. You can't drag your camper to the dealership faster than that!
I did ours...
Good luck,
Heather
ok, thanks, sounds easy........................i can do that.........BUT, how do i measure a toilet i don't have yet? ok, guess i have to wait til it gets here, ugh........lol
lotsip is offline   Reply With Quote
Old 01-21-2014, 12:21 PM   #112
Phat Phrog Stunt Crew
mackman1994's Avatar
My redesigned 300s should be here Thursday. Glad we will be having a heat wave this weekend. It is supposed to be clear up into the low 30's. Great time to get the toilets swapped.
F-350 Lariat 6.7 Powerstroke
2014 Heritage Glen 356QBQ
mackman1994 is offline   Reply With Quote
Old 01-21-2014, 12:40 PM   #113
Grizzlygibbs's Avatar
Not a bad video put out by Dometic on how to install. When you measure for clearance make sure you measure from the wall to the closet bolts/nuts to determine your clearance. If you are installing a 310 in place of a 300 you have at least 10" of clearance from the back wall to the closet bolts/nuts. Here is the spec sheet for the model 310 and for the model 300. you want the measurements from the midpoint of the toilet base to the wall on each toilet. hope this makes sense.
http://www.dometic.com/a5147e5a-ba32...58126a72.fodoc
http://www.dometic.com/adb7aee0-ceeb...1c607237.fodoc
Dometic 310 Series Porcelain RV Toilet - YouTube
2008 Toyota Tundra Crewmax Limited w/tow mirrors, 5.7L, 4.30 gears, six speed tranny, towing package, Firestone Ride Rite airbags.
2014 Rockwood Roo 233s, PI HW30-C, Equalizer 10k 4 way hitch,
Grizzlygibbs is offline   Reply With Quote
Old 01-21-2014, 12:41 PM   #114
Todouble's Avatar
Are these toilets used on all new forest river RV's? I just bought a new 14 prime time crusader in dec. sticker says mfg was 9/27/13. Can't go look because it's in storage but I wonder if I have this problem toilet? I haven't used the RV yet because it's been too cold here but I think I would like to change that baby now before I start to use the tank for the first time. Help from any crusader owner please.
Todouble is offline   Reply With Quote
Old 01-21-2014, 03:39 PM   #115
larrys2112's Avatar
I was sent a replacement 300 that was supposedly redesigned in September of last year to fix the odor issue. I replaced it myself even though my camper is still under warranty. It was shipped directly to me by Diane. When I removed the old toilet and took it out of the camper the odor went away immediately even with the black tank fully exposed. I clean the black tank to a pristine level every time we get home from camping. LOL We haven't had a chance to camp with the new toilet installed yet so it's yet to be seen if this new toilet design indeed fixed the issue.
On the stinky side of the issue, I took the old toilet to the ditch and turned it upside down. There was probably a half of a gallon of brown waste that dumped out. Talk about disgusting!!!
2016 Rockwood Windjammer 3008W Diamond Package
2016 Toyota Tundra Double Cab 5.7L SR5 4x4
larrys2112 is offline   Reply With Quote
Old 01-21-2014, 04:38 PM   #116
jawga's Avatar
You can do it yourself and takes about 15 min. I didnt measure but ours fit right in with no problem. i would just uninstall the old one and test fit the new one. it will take just as long to do that as trying to figure out the measurements and making the measurementa. also if u have uaed the toilet already be careful and dont top it over till u are outside because it will leak water on u
jawga is offline   Reply With Quote
Old 01-21-2014, 08:16 PM   #117
lotsip's Avatar
Ok thanks, i was worried it might not fit, but, diane said my 310 would be shipping from orlando , might get it tomorrow, as I am in Homosassa, close to orlando !........i will do as u suggested and just take the 300 out, carefully, then see how the 310 fits........seems from the docs that the 310 is an inch or two longer, but, there is a bit of extra space, so, hopefully will fit ! will keep u posted
Old 01-21-2014, 09:03 PM   #118
Slympicins's Avatar
Dometic model 300 odor problem and replacement
Just bought a new 2014 Flaggstaff 27RLWS manufactured late July 2013. Not sure of the serial number but for sure it's a 300. Haven't seen anyone reply as to whether or not the new upgraded 300 has the same issues. Can anyone advise as to how that one works?
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 01-22-2014, 03:55 PM   #119
Slympicins's Avatar
I sent an email to Diane over at Dometic and inquired about the recent modification on the 300 model. I sent a picture of the serial number which turned out was made prior to the modification on that model. Dometic is sending me the new 300 with the modification today. I can not say enough about their customer service and Diane. I did check with the dealer and they have heard of the issues surrounding the older 300 model but nothing has been said or complained about with the modifications. The dealer did say if there was any problem for which they needed to be involved, to let them do so with no problems. Northgate RV here in Knoxville and Ringgold Ga. are the best dealers in Eastern Tennessee hands down.
Chuck and Joanne
Old 01-22-2014, 06:56 PM   #120
lotsip's Avatar
Got my 310 today, pulled out my 300 lickety split and popped in the 310, piece of cake!
