Old 07-25-2016, 03:48 PM   #241
Thank you, I will keep that for future reference. The water will stay in the bowl for about 3-4 hours but does have a slow drip. There are no odors coming from the tank at all. I have a very sensitive sniffer and not to gross you out, I can actually put my nose right in the opening when it is open and there is no odor. It is coming from the opening at the back of the toilet.
For 2 weeks I have cleaned, investigated, and searched and then I found this forum which describes everything that is happening.
Dan and Cheryl
2007 Chevy Silverado 1500 4X4
2013 Rockwood Roo 19 Hybrid
Shandy is offline   Reply With Quote
Old 07-25-2016, 03:54 PM   #242
Wobbles's Avatar
Dan and Cheryl
Best of luck to you. This took care of my problem. I am happy that I do not need to purchase a new one right now. I do plan this winter, on getting a new 320 Series if it will bolt on without any added issues.
Please do post here about your results with Dometic service.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2015 Grey Wolf 26BH
Wobbles is online now   Reply With Quote
Old 07-26-2016, 09:44 AM   #243
Just got an email back from Diane. This is what it said: "We did make a modification to this toilet in September 2013. Your toilet was assembled prior to that time. I will send you a replacement toilet at no charge."
Now we just have to wait for the new throne and then a good airing out.
I am so glad I found this forum. It is sooooo helpful.
Dan &Cheryl
Old 07-27-2016, 06:12 AM   #244
Use the Force Roo
Exclamation
Originally Posted by ts12i30 View Post
We had a similar experience with our brand new 27BESS last month. Four days into our first camping trip, there was a foul odor in the bathroom. The odor was not coming from the black tank and the fan was off. In desperation, I removed the toilet. There was a problem with the flush valve that allowed the nasty stuff to build up under the bowl. Dometic sent a replacement to the campground via next day air.
I am having the same problem, however I bought my 2013 Rockwood Roo 233s used from the dealer and the warranty info says original owner. Thoughts out there if Dometic will still honor the warranty or will I be buying a new Dometic instead?
BGlickster is offline   Reply With Quote
Old 07-27-2016, 08:28 AM   #245
They didn't ask that many questions. They just asked for the serial number and where to send the new toilet.
2014 Flagstaff V-Lite 30WTBS
2008 Surveyor SV-234 (SOLD, but not forgotten)
2008 Nissan Titan Pro-4x crew cab
smithmdsmith is offline   Reply With Quote
Old 07-27-2016, 05:27 PM   #246
Go a head and email them the sticker on the side of the toilet but don't tell them you are second owners, though I don't think it matters. The toilet might be faulty.
I sent them a short note, my sticker and mailing address on Mon and I received a response on Tues and just now received the new toilet by Purolator.
Old 07-27-2016, 10:48 PM   #247
Use the Force Roo
Really have to say I am quite impressed with Diane, who was very helpful and advised me my Dometic 300 was faulty from the start and would be sending me a replacement. I would have to install myself, since it is not under warranty, but I am able remove and install the toilet. She even gave me some helpful tips and advice, to not "tip over the toilet when removing it"...
Thanks to the forum and this thread in particular, which was vital in getting me pointed into the right direction for my problem...
Old 08-26-2016, 10:32 AM   #248
We have a 310 that is 3 years old and has just started with this smell --- unbearable!!
I called Dometic and, sure enough, they are shipping me a free replacement. She balked, saying there was no issue with the 310, but changed her mind.
It sounds easy enough to replace.
Larry Tiner is offline   Reply With Quote
Old 08-26-2016, 12:10 PM   #249
BGlickster posting is correct. DO NOT tilt the old toilet when you remove it. You WILL get an abundance of brown liquid pouring from the rear of toilet. You recited having a model 310. IS it a 310 OR 300? The label located on right/rear will recite this information. The removal/reinstall of toilets takes approximately 30 minutes. Make sure Dometic sent a new base (floor) foam gasket and use it. My 300 also leaked and was replaced by me. Dometic is VERY generous in sending an upgraded toilet.
l001952119 is offline   Reply With Quote
Old 08-26-2016, 03:31 PM   #250
It is a 310.
The tech at the RV store thinks I'm crazy. He's never heard of a faulty toilet. He says to get on the roof and check the vent to blockage. Another suggestion was to use a different chemical.
I usually dump and rinse out daily. He said I should dump only when it is full. Any thoughts? My guess is all the testimonials found on this link were solved without the use of a tech, so they aren't savvy to the issues mentioned here.
