Old 08-26-2016, 02:50 PM   #251
Smile
Originally Posted by Larry Tiner View Post
It is a 310.
The tech at the RV store thinks I'm crazy. He's never heard of a faulty toilet. He says to get on the roof and check the vent to blockage. Another suggestion was to use a different chemical.
I usually dump and rinse out daily. He said I should dump only when it is full. Any thoughts? My guess is all the testimonials found on this link were solved without the use of a tech, so they aren't savvy to the issues mentioned here.
The Tech must be new! The toilet issue has been in existence for at least two years and well publicized! When you remove the existing toilet (keep upright) and tilt over grass, you will get at least a quart of pure brown liquid "fertilizer"! The Tech has not kept abreast of the RV world issues. The remainder of his recommendations display the lack of experience!
l001952119 is offline   Reply With Quote
Old 08-26-2016, 04:46 PM   #252
My tech told me the same thing. He was shocked when they over nighted a new toilet.
2014 Flagstaff V-Lite 30WTBS
2008 Surveyor SV-234 (SOLD, but not forgotten)
2008 Nissan Titan Pro-4x crew cab
smithmdsmith is offline   Reply With Quote
Old 09-03-2016, 10:05 AM   #253
LandJ's Avatar
The Dometic 300 is still a problem. We have had our 2016 Rockwood for just about a year. All summer long my wife has scrubbed the bathroom over and over, but couldn't get rid of the smell. We blamed the grandkids and implemented a "sit only" policy.
Turns out we have a faulty toilet verified by using a mirror and flashlight that someone recommended online. There is about 1" of brown liquid between the halves of the toilet bowl. I don't see solids, just liquid that has partially evaporated. The smell is driving us crazy.... I complained to the dealer and he apparently is unaware of this defective toilet. I'll be calling Dometic when they open on Tuesday after Labor Day.
I'm happy to finally figure this out, and angry that it was allowed to happen in the first place. This thread was started in 2013..... why was a defective toilet installed in my trailer that was manufactured in August of 2015???
_________________
John and Linda
2016 Rockwood 2604WS
2017 Ram 3500 CTD SRW
2015 - 36 nights
2016 - 47 nights
LandJ is offline   Reply With Quote
Old 09-07-2016, 04:28 PM   #254
Dometic Toilet
One word of caution on the Dometic model 310: remove the valve completely when winterizing! We have had 2 freeze during the winter causing a hasty trip to the dealer during our first spring usage.
It turns out that the replacement part (catalog) indicates that it should be removed in the winter due to the small amount of water that may be held up in it. After starting our camping the last 2 years, we have had the same issue - now we remove the valve on the 310. (Just finished winterizing.)
Double Dutch
2013 CC Silverback
2008 2500 6.7 Diesel w/delete
84 Days 2016
DoubleDutch is offline   Reply With Quote
Old 09-07-2016, 06:06 PM   #255
Do you not use RV antifreeze when winterizing?
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 09-08-2016, 12:33 AM   #256
A lot of people in the south don't use antifreeze. I have never have. I have always drained the lines and then blown them out with an air compressor set to about 30 psi.
Unfortunately, in my first year with this trailer, I learned about the Dometic 310 valve not draining this way as well. My first outing was wet.
I never winterized this last winter because I was camping so often and didn't want to deal with that stupid valve. I just turned the heat on when it was going to freeze. The cost of the extra propane versus the cost of the valve versus the cost of the antifreeze is basically a wash for me in Texas.
Old 09-08-2016, 06:06 AM   #257
I understand some not using antifreeze if the climate is only cool but if you've had problems with things freezing and breaking, I'm pretty sure I'd be considering its use as who knows where else in the system water might be trapped.
I sure wouldn't want some inaccessible elbow splitting somewhere in a wall or under the shower.
Old 09-08-2016, 07:41 AM   #258
LandJ's Avatar
Just to follow up.....
Dometic would only replace my defective 300 with a new 300 at no charge. They claim the 300 problems have been fixed and they were unwilling to budge at my request for a 310. I explained that many were upgraded to the 310 and that I felt that it would be fare if they did the same for me. I also voiced my displeasure that they had continued to allow a known defective unit to be installed in new trailers for at least 2 years. I also let them know my displeasure that I had to deal with this problem for a year because my dealer was unaware of the issue when i asked about odors in the bathroom of my new trailer. I blamed the grandkids and my wife spent many hours scrubbing the walls and floor thinking the odor was caused by the kids. This has been an unpleasant experience from start to finish...
I did order a 310, however, they required a $50 up-charge.
_________________
John and Linda
2015 - 36 nights
2016 - 47 nights
Old 09-09-2016, 11:54 AM   #259
My 320 did it, but they did replace it
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 09-09-2016, 01:30 PM   #260
My 310 did it, too. They replaced it
