Old 09-17-2019, 05:28 AM   #1
Dometic toilet
HI,
we have a 2020 Rockwood ultra lite 2608BS and every time we flush the toilet water sprays all over the floor, even with the lid down! Is there a way to reduce the water pressure at the toilet?
Noahron3 is online now   Reply With Quote
Old 09-17-2019, 08:06 AM   #2
Head Rambler
Is it spraying out of the bowl from under the lid?
Are you using a pressure regulator on the inlet to the RV? If so what is it set to?
Can you tell us the make and model of the toilet?
If you're not using a regulator in the inlet to the RV, you should be and it should be set to ~50psig.
Gotta go campin!
Old 09-17-2019, 08:15 AM   #3
RV There Yet?
IsleDog's Avatar
are you using a water pressure regulator on your hose coming into the camper or is this from tank pressure?
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
IsleDog is offline   Reply With Quote
Old 09-17-2019, 06:46 PM   #4
No from the tank and the water pump!
Old 09-18-2019, 09:41 AM   #5
Head Rambler
I'd put a pressure gauge on the system somewhere and run the pump to see what pressure it shuts off at. The majority of the pumps have an adjustment on the switch that you adjust the pressure a bit.
Gotta go campin!
Old 09-18-2019, 09:55 AM   #6
Flybob's Avatar
Check the small opening in the top of the toilet where the water is entering the bowl. It is possible there is an obstruction there that is causing a restriction and a spray verses a stream of water into the bowl.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 09-24-2019, 06:43 PM   #7
If all else fails, find a stainless steel washer that will fit in the water connection and act as a flow restrictor.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 09-24-2019, 06:58 PM   #8
Otegoans's Avatar
Have you checked the flush valve and its connections at the back of the toilet? These are prone to cracks when excessive force is used to flush them.
Otegoans
Ken and Wendy
'15 silverback 29RE
'13 GMC 2500HD
Duramax/Allison
Otegoans is offline   Reply With Quote
dometic
