Old 07-04-2016, 07:45 PM   #11
Flybob's Avatar
There is no definite answer to this question. Depends on the water source and the climate. Try this. Fill a large glass with water from your FW tank. Cover it an sit it on the counter in your RV. Just before you get ready for your next trip. check the glass. Are OK drinking the water in the glass. In most cases the water in your FW tanks will be very similar. For those that say by adding fresh chlorinated water will refresh the tank. Top off the glass from above with fresh water and check it again. Make you own decision.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-04-2016, 07:52 PM   #12
Ford Idaho's Avatar
Once exposed to light and air Clorox breaks down to it's base elements rather quickly.
So if you use Clorox or other liquid bleach to sanitize and clean make a fresh bottle/batch every day.
Rinse any container with plenty of water to remove any salt residue.
Old 07-04-2016, 08:45 PM   #13
Wandering's Avatar
I keep fresh water in my tank between trips. Just hope it helps keep it sanitized. Then refill and flush with fresh before the trip.
Forester 2451s
Forester 2451s
Wandering is offline   Reply With Quote
Old 07-04-2016, 09:38 PM   #14
If you are filling with well water with any minerals in it make sure to drain. The aluminum tank on hot water heaters will react to the minerals in the water.
markb422 is offline   Reply With Quote
Old 07-04-2016, 11:26 PM   #15
We drain ours every time we return from a trip. I think the trick is to fill it with as much water as one plans on using, thus little or no waste. I just do not feel comfortable in leaving a tank/ or part of a tank of water sitting in 90 degree heat for over a week. Always sanitize in the spring and go from there.
Brandon 2
2014 2500TS
Sun Seeker
brandon 2 is offline   Reply With Quote
Old 07-04-2016, 11:49 PM   #16
waltdk's Avatar
I am just filling my first fresh water tank. You can't get much newer than that. How much chlorine do you recommend for each tank?
Walt Krein ~ Krein's Kruiser
waltdk is offline   Reply With Quote
Old 07-05-2016, 04:42 AM   #17
ilmor's Avatar
If the system is already sanitized, sometime ago I figured read / determined that 1/4 teaspoon per 10 gallons is sufficient maintenance chlorine. I've been doing this for 15 years without issues and always have at least 10 gallons in my tank (except during the winter when its winterized).
edit - p.s. I don't drink water from the tank.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 07-05-2016, 06:44 AM   #18
Wolverine 1945's Avatar
I drain our complete sys after each trip,,, refill with soft water & TastPure,,, 2 or 3 days before we go on our little trip !!!
Wolverine 1945 is online now   Reply With Quote
Old 07-05-2016, 06:57 AM   #19
jeff64's Avatar
Originally Posted by WFD View Post
And I am in the other camp...when back home and parked that length of time, I drain it and use it on the lawn or garden so it's not wasted. I would rather put fresh water back in it if we are home a while....all comes down to personal preference.
X3
I prefer the clean fresh water every time I go too, don't need any additional bacteria growing in the system( or mine either, not for 15 gal. of water!). I will sanitize the tank and lines if I haven't used it for a while too.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 07-05-2016, 12:01 PM   #20
We drink and make coffee from only bottled water (ozarka). We use the tank for shower and flushing.....maybe cooking, if boiling is in the recipe.
We do not drink the local water when hooked up at campsite, either.
As such, we fill in the spring, and top it off as needed, from ONLY chlorinated sources; drain for winterization.
No muss, no fuss.
2012 Ecoboost Screw, 3.31 (yes....really) rear end.
2016 Flagstaff 26FKWS, about 7500 loaded
Retired AF Mustang.....Picker always looking to jam.
Major Oz is offline   Reply With Quote
drain, fresh water, water
