Old 01-14-2016, 10:08 AM   #1
Drain line leak
New washer/dryer when used floor got wet. Opened up wall and drawer and found drain pipes leaking. What can I do to stop the leak. Hate to cut pipes if possible seal it. Leak appears to be at an elbow as it exits the closet I have pics but not sure how to post. Please give me some advise. Thanks.
Deputypunkin is offline   Reply With Quote
Old 01-14-2016, 10:26 AM   #2
Left Coast
If drain pipe is pex, they make repair push-on fittings....you cut the line at the leak and insert....there also is a release thing they call a tool to make removing the push-on fittings possible.....Home Depot/Lowes carry these. Are the fittings in that area clamped on with a metal band?
Old 01-14-2016, 10:52 AM   #3
AquaMan's Avatar
The drain liine is probably pvc. If it's not under warranty, cut the elbow/line out and fit with new. May be tough to maneuver, but the process is easy.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
drain, leak
