Old 09-27-2014, 07:36 PM   #1
Drain plug in hot water heater will not buge.
I have a 2006 Cherokee and I don't think the drain plug has ever been taken out. I soaked it with WD40 bought a 1 1/16 6 point socket but can not get the thing to budge. Don't want to force it too much as to do damage to beyond repair or damage something else. Anyone have a trick up their sleeve to get it off? Thanks
Happy Dude is offline   Reply With Quote
Old 09-27-2014, 07:50 PM   #2
Ford Idaho's Avatar
Try tapping the end of the ratchet with a dead blow hammer, the sudden shock may nudge it.
Old 09-27-2014, 07:54 PM   #3
Campin Cajun's Avatar
Instead of WD40 try some BBQ lighter fluid.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 09-27-2014, 08:04 PM   #4
arpipeliner's Avatar
PB Blaster. Several soaks with any solvent. As Idaho says bounces and jars will help to breaks it loose.
arpipeliner is offline   Reply With Quote
Old 09-27-2014, 08:12 PM   #5
GLCM Warrior
Lefty59's Avatar
I've had good luck using a paper towel soaked in vinegar. Let it set on the spot/threads for a few hours...giving it time to work its way in...and usually whatever it is will then come loose. Remedy was suggested by a plumber and has worked for me.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 09-27-2014, 09:15 PM   #6
Thanks I'll give it a try in the am.
Old 09-27-2014, 09:18 PM   #7
After you've put your solvent of choice on the threads, spend a few minutes tapping on it with a hammer. The vibes help the solvent get into the threads.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 09-27-2014, 09:41 PM   #8
Thanks for the tip. Hope this works, really don't want to have to replace the hot water heater if I force it and break something.
Old 09-27-2014, 09:50 PM   #9
I really appreciate all the quick and informed responses. Here is another question. Assuming I get the plug out is there something I should do to flush out the hot water heater like CLR ?
Old 09-27-2014, 10:33 PM   #10
Mix some ATF with some acetone.. Brush it on.. Give it a few minutes and give it a try..
2010 Georgetown 300FWSSouth Florida
speedjester is offline   Reply With Quote
drain, heater, hot water, water, water heater
