Old 09-05-2016, 09:55 PM   #11
Originally Posted by northstar1960 View Post
Good idea ! looks like you really don't even need the brass plugs . if the seals are leaking it would come out where the handle enters the housing . this way you'll have a weep hole to let you know when to replace the seals
in our area, an open hole like that would be an "invite" to the mud daubers to "come on in",...... around here, they'll stop up any hole they can find,..... I believe if I'm going to use the straw to spray into the cavity, I can actually do this mod with a much smaller hole and then close it up with a small screw,....
fella10 is offline   Reply With Quote
Old 09-06-2016, 09:46 AM   #12
Sticky drain valves
Thats a great idea Gordonsick.My black water is tough to work so will try that. Thanks
otisite2016 is offline   Reply With Quote
Old 09-06-2016, 10:19 AM   #13
Dave Lyon's Avatar
I recently tried the Thetford valve lubricant......waste of money.
I used silicone spray and it worked perfectly.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 09-09-2016, 01:59 PM   #14
Gordonsick,
I did the mod and am pleased with the results, thanks for your post,....
ID:	119807   Click image for larger version
Old 09-10-2016, 10:34 AM   #15
Wolverine 1945's Avatar
White Lithium comes in spray can !!!
Wolverine 1945 is offline   Reply With Quote
Old 09-11-2016, 05:18 PM   #16
When I googled White Lithium spray, I found a WD-40 White Lithium product. Standard WD-40 is petroleum based and cold damage the drain valve seals if they are rubber-based.
Unless I had clear evidence that the WD-40 White Lithium is not petroleum based, or that the drain valve seals are not rubber-based, but are made of something like Delrin or Teflon, I wouldn't use the product.
On the other hand, Silicone works and is safe.
Gordon Sick, Calgary
2015 Berkshire 34QS
2005 Acura EL (aka Honda Civic)
gordonsick is offline   Reply With Quote
Old 09-12-2016, 07:30 AM   #17
The White Lithium I use is fortified with PTFE ???
Old 09-12-2016, 10:28 AM   #18
Jimsue's Avatar
Push The Front End
2015 F350 Lariat Crewcab DPS SWD 4x4
2013 Sabre BKOK 31
Demco Hijacker Autoslid
Renogy Solar Suitcase
Progressive Industries EMS
Sea Eagle 420 Tandem Inflatable Kayak
Jimsue is offline   Reply With Quote
Old 09-13-2016, 06:50 AM   #19
Originally Posted by Jimsue View Post
Push The Front End
Or,,, Polytetrafluoroethylene !!!!
Syncolon is easer to type !!!
Old 09-13-2016, 01:04 PM   #20
That's Teflon, which is a solid lubricant. It isn't the solvent in the spray. The spray could still be petroleum-based.
2015 Berkshire 34QS
cat, drain
