Old 11-20-2015, 02:56 PM   #1
Drain Valves
There are two drain valves on the bottom of my travel trailer marked "Low Point Drain". What are these for?Click image for larger version
Name:	ImageUploadedByForest River Forums1448049307.268760.jpg
They're not for the fresh water tank. This drain is supposed to be for that. Click image for larger version
Name:	ImageUploadedByForest River Forums1448049411.644145.jpg
PCStrope is offline   Reply With Quote
Old 11-20-2015, 03:01 PM   #2
Flybob's Avatar
They are cold water lines ( blue) and hot water lines (Red). They will drain ( via gravity) much of the water from the water lines, but not all of it. You need to open hot and cold faucets. You will need to blow out and /or add antifreeze if it gets below freezing where you live. I recommend you replace the screw on caps with 1/4 turn valves. This will make future draining much easier.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-20-2015, 03:03 PM   #3
Just A Member
EDABEUT's Avatar
These are for draining the hot and cold water from the whole RV. Open all your faucets and the hot water heater drain and then remove these caps and all the water should drain out. You should do this after each trip.
Ed & Brenda
2015 Coachmen Freedom Express
Liberty Edition 297RLDS
2013 Silverado 1500 4x4 6.2L Max Tow
EDABEUT is offline   Reply With Quote
Old 11-20-2015, 05:03 PM   #4
Thanks. This information has been very helpful. Too bad the owners manual couldn't have been this specific.
Old 11-20-2015, 05:15 PM   #5
I think the common consensus on many RV owner's manuals is that they make good kindling.
Iwritecode is offline   Reply With Quote
Old 11-21-2015, 07:46 AM   #6
cpaulsen's Avatar
Take the caps off and install a pvc ball valve......a lot easier to drain.
cpaulsen is offline   Reply With Quote
drain, valve
