Old 04-24-2016, 07:34 PM   #1
Rvrphdawg's Avatar
Drain water filter?
Just got home from our 4th weekend trip in our 3011ds. I drained the hot water tank, and the low point drain. The thought hit me that I don't think I've heard anyone mention draining the whole-house water filter between trips. Mine is hidden in a closed compartment I the back of a basement compartment. I would assume that it's not a good idea to leave standing water in one of those for any length of time. I removed it , and water poured into the compartment. I thought I'd drained everything I knew how.
Any suggestions for this newbie?
Forester 3011DS
Rvrphdawg is offline   Reply With Quote
Old 04-24-2016, 07:50 PM   #2
downtime's Avatar
I cut a gal jug about six inches from bottom and put it under my filter on Wildcat 30lswb and it catches any extra when the filter is unscrewed. I drained my system as well on after my last outing(removed filter) used air (20psi) at the city fill port and went from furthest to closest after draining the hot water tank and flipping bypass valve. Just what I do and hope it helps.
Life is short and none of us are all that Tall !
downtime is offline   Reply With Quote
Old 04-24-2016, 07:52 PM   #3
Oaklevel's Avatar
Don't have a water filter but draining the water heater or lines more than annually for winterizing it's not necessary.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Oaklevel is online now   Reply With Quote
Old 04-24-2016, 07:56 PM   #4
Coops1's Avatar
As you have found out they are a pain to deal with, I completely removed the one in our trailer and use an external one.
26WRB - V-Lite
Denali HD LML
Coops1 is offline   Reply With Quote
Old 04-24-2016, 07:59 PM   #5
Rvrphdawg's Avatar
Thanks for the input guys! Great idea using the milk jug. That compartment isn't the easiest place to access. This forum is great for getting advice. Looking forward to the time that I can be of help to others!
Forester 3011DS
drain, water, water filter
