Old 02-20-2019, 05:59 AM   #1
Draining fresh water tank
We just purchased a used 2013 Palomino Solaire 297 RLDS and the fresh water tank is full can someone shed some light on how I would go about draining it?
captrcurtis is online now   Reply With Quote
Old 02-20-2019, 06:23 AM   #2
nomad297's Avatar
Are You Sure?
Are you sure the tank is full, or are you just judging it by what the indicator lights say? The indicators are pretty unreliable. As far as draining the tank on your specific model, sorry, but I can’t help you with that other than telling you that you can get most of the water out by turning the pump on and running a faucet. There is a drain somewhere, though.
Bruce
Old 02-20-2019, 06:27 AM   #3
Ok thanks yes there is a lot of water in the tank and I believe the monitor is fairly accurate I ran the the kitchen and bathroom faucets for 15-20 minutes and now shows 3/4 don't like the idea of running the pump long enough to drain 40 gallons of water
Old 02-20-2019, 06:34 AM   #4
nomad297's Avatar
Don’t worry about the pump — it can handle it with ease. Turn on all of your faucets if you want it to drain faster.
Bruce
Old 02-20-2019, 06:36 AM   #5
Bruce
Ok thanks I'm not sure how long the water has been in the tank thought I'd run some bleach through it also. What are your thoughts?
Old 02-20-2019, 06:50 AM   #6
nomad297's Avatar
I wouldn’t add the bleach now because it won’t mix with all of the water in the tank thoroughly. I would wait until the tank is drained, then refill it with sanitizing in mind.
Bruce
Old 02-20-2019, 06:59 AM   #7
Bruce
Great thanks for the feed back I've been away from RV'ing a long time but was into boats up until a couple of years ago.
Now that we are retired going to start doing some traveling.
Old 02-20-2019, 07:47 AM   #8
Dave Lyon's Avatar
Bruce
X2 - 1/4 cup of bleach for 15 gallons of water. Let it sit overnight and then flush out the bleach/water solution.
If you're not sure the source of the water or how long it has been in the tank, you may want to sanitize twice.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 02-20-2019, 07:53 AM   #9
Thank you we have no idea how long or where it's come from
Old 02-20-2019, 08:06 AM   #10
Mr. Dan's Avatar
On most/many units, you can crawl under the fresh water tank and find a drain pipe. Mine has a screw cap on it. Some have one of 2-3 types of valves. You don’t see any drain pipes coming down from your FW tank?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 40; booked = 49
drain, fresh water, tank, water, water tank
