02-15-2018, 09:22 PM
Draining hot water tank
I just bought a 2018 shamrock 233s. I've looked all over the bottom of the camper and can't find the valve to drain the hot water tank. Could anyone help me with this?
02-15-2018, 09:27 PM
Yes... you'll have to open/remove the outside water heater door.
If you have a Suburban water heater, the "plug" will be metal and attached to a sacrificial anode rod. You have to unscrew it AFTER the water is cool and you have released the pressure.
If you have an Atwood water heater, the "plug" will be plastic. You have to unscrew it AFTER the water is cool and you have released the pressure.
02-15-2018, 09:29 PM
thank you very much for your quick reply. Still trying to get adjusted from a trailmanor to the shamrock
02-15-2018, 09:30 PM
You have to remove the outside WH cover and remove the large plug at the bottom of the tank. Use a 6 point socket. Be very sure you have the 110-volt electric turned off. Reach up and flip open the Pressure Relief valve at the top of the tank. On some models, an anode rod is attached to the plug.
02-15-2018, 09:33 PM
Thanks! Glad I signed up for this forum.
02-15-2018, 09:35 PM
Is your water heater made by Suburban or Atwood?
02-15-2018, 09:49 PM
Water heater should be very similar if not identical to the Trailmanor.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
02-16-2018, 07:52 AM
One more thing, what's the switch do on the hot water heater? Its located left of the anode rod.
02-16-2018, 07:53 AM
Heater yes, but the trailmanor had a valve beneath the camper to drain the hot water tank
02-16-2018, 08:02 AM
IF it's a black rocker switch- it turns the
120v AC heating rod ON/OFF in your water heater.
Shut off the switch now and don't turn it back on until you have refilled your hot water tank next season.
Failure to do this can result in nearly instant burn out of the heater rod.
Ask me how I know this....
Peace!
Dan & Rita D
02-16-2018, 08:09 AM
My previous TrailManor 3023 had the exact same Suburban that my Flagstaff does.
To the OP, this FAQ thread may help you understand the operation of the electric heating element on your water heater:
http://www.forestriverforums.com/for...ore-36197.html
Hope it helps, and welcome to FRF from another former TrailManor owner.
2011 Flagstaff 831 RLBSS
02-16-2018, 01:53 PM
1-1/16" socket needed.
Since no one else mentioned it, this is most easily done with a 1-1/16" socket and a short (4"-6") 1/2" drive extension and ratchet. A little tricky to find the socket but it's only $ 2.98 at Home Depot. I've never had a problem using a 12-point socket--the anode only needs to be tight enough to seal the plastic ring gasket. But if you insist on a 6-point socket, Home Depot has those too.
Larry
02-16-2018, 02:11 PM
Larry
Usually never a problem using a 12 point socket on the metal, Suburban style plug/anode.
It's the plastic Atwood plugs that a 12 point chews up pretty easily and for those, a 6 point is a much better socket choice.
02-16-2018, 02:50 PM
The switch to the left of the anode rod is the switch to turn on and off AC operation of the WH. If you have an anode rod it is a Suburban WH. My Trailmanor had a Suburban water heater and the only way to drain it was to remove the anode rod or via low point system drains.
TST Tire Monitors
2 100W solar panels
02-16-2018, 02:56 PM
Ham Call N8SAC
I always remove the 3/4” plug from the bottom of the heater and replace it with a 3/4” X 1/4” reducer then put a 1/4” valve in the reducer. That way I can just open it to drain the tank. As per the anode Don’t use one as it is useless in my case I don’t heave water in tank but a few days in the year.
02-16-2018, 03:03 PM
It doesn't take long for damage to occur without an anode rod. If you want to see for yourself. Replace the anode rod and check it after 6mths to a year.
TST Tire Monitors
2 100W solar panels
02-16-2018, 06:48 PM
Bene Gesserit Rule
For some HW tanks the anode rod is the drain. Not a super efficient place for a drain but it gets most water out. Better if the van is leaning over a bit (jack up the other side). And YES, wait till the water cools down or you will get scalded.
02-16-2018, 07:33 PM
American-Standard comes that way
Our 2002 Nash came that way (or prior owner did that mod). The heater is neither a Suburban nor an Atwood, could be American-Standard A-SVDE6 or somesuch, manual is not at our fingertips. The major design difference between it and the Atwoods and Suburbans is that all the electrical stuff is on one end and all the propane stuff is at the other end.
Larry
02-17-2018, 01:32 PM
Denver, CO
Larry
Yeah and Atwood's are aluminum, no anode, and suburban are steel with anode plugs. Plugs size are different the 1 1/16 are the suburban. Not much similar except they fit in the same home and use electricity and propane. Lol
2017 Fuse 23T
