11-27-2013, 04:42 PM
Draining hot water tank question?
Is there any other way to drain tank besides removing heater element?
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
11-27-2013, 04:47 PM
Remove the anode, not the heater element.
11-27-2013, 05:39 PM
I meant either one, no other way? I was think of maybe draining it after camping trips.
2014 XLR 27 HFS
11-27-2013, 05:40 PM
Engineer of Crazy Train
Buy an anode with a drain cock.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 - 18
Come read my Camping Blogs
11-27-2013, 06:06 PM
I don't think they make a anode rod with a drain, rod is solid.
2014 XLR 27 HFS
11-27-2013, 06:08 PM
Camco 11533 RV Anode Rod with Drain for Aluminum Water Heater by Camco http://www.amazon.com/dp/B0024ECD2I/..._ZSNLsb1YQN9PG
Locomotive Engineer
11-27-2013, 06:11 PM
Awesome, thats what I am getting when I change the anode rod.
2014 XLR 27 HFS
11-27-2013, 06:16 PM
They are not for Suburban heaters, Atwoods have aluminum tanks.
11-27-2013, 06:19 PM
Why wouldn't it work?
2014 XLR 27 HFS
11-27-2013, 06:22 PM
It looks like a sure fire way to let the anode threads rust into the tank unless you are religious about making sure you remove the anode once a year and making sure the threads keep spinning freely. Unfortunately too many people are too lazy to remember doing that and will just open the drain-cock instead.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Rockford, Michigan
11-27-2013, 06:26 PM
Good to know. Taking that off my Amazon.com wish list.
Locomotive Engineer
11-27-2013, 06:28 PM
I put anti seize on threads, never have a problem.
2014 XLR 27 HFS
11-27-2013, 06:29 PM
Read your Suburban manual, the Atwoods require a different anode material than the Suburban heaters.
11-27-2013, 06:58 PM
Here is a video on the subject, thanks Oldcoot for bringing it to our attention.
2014 XLR 27 HFS
11-27-2013, 07:00 PM
Different size threads (IIRC).
11-27-2013, 07:04 PM
Threads are the same, see video I posted.
2014 XLR 27 HFS
11-27-2013, 07:54 PM
Always Learning
I've read concerns on here that the anode with the drain don't allow the water to glub out fast enough for bits of crud to come out when you drain it.
There was a neat solution where someone put in a T and on one side out in a quarter turn shutoff valve that would make draining it really convenient.
11-27-2013, 08:35 PM
Open the hot water facets in the trailer when drain the hot water tank it will flow better. I agree with all that was said about not using the anode with the flow through valve on suburban heaters
2011 GMC 2500HD Diesel
12-19-2013, 09:39 AM
DONT SEE the prob....just take off annually flush out tank good and put back in, get to insp anode, keep from seizing and know u flush out tank good. I can not believe how much deposits came out of my old rv's tank, the anode was prob reduced to a stub. it did not have a drain plug with anode, it was 14 years old.
12-19-2013, 10:47 PM
Anacortesians
One thing I've done on our rig is to make an aluminum water chute that sit under the anode rod hole and extends over the edge of the WH compartment. Initially, I was concerned about water pooling alongside the edge of the compartment and working its way into the structure.
Now I'm sure the water goes overboard when I drain the heater!
Frank and Eileen
No longer RVers or FR owners
