Old 09-27-2010, 04:08 PM   #11
Originally Posted by 3 Happy Campers View Post
WOW did you get the electronic leveling on your unit? Iím jealous
Yes sir we did get the auto level. Got the unit home and the auto level failed to work. After tightening a loose power wire to the hydraulic motor she leveled to my amazement. No more boards, bricks, looking at levels, walking around to look at bubbles and most of all, no more wobbling of the trailer when someone is walking round as the auto level jacks take nearly if not all wobble away.
Also, about the low water finally called back and told me to look in a closed compartment inside our large (see through) storage area under the bedroom in the front. The compartment is
accessible behind a slide door that is fastened with one screw. There should be a valve for each hot and cold water drain. Yahoo ! terrible to get excited over such a find.... If infact the drain valves are there. ha
gmccall is offline   Reply With Quote
Old 09-28-2010, 09:48 AM   #12
found the low water DRAINS
They were behind the slide door in the big storage area.
Thanks all for the help
Old 11-14-2010, 11:23 AM   #13
The valves for the low point drain are accessed in the basement storage area. Ther will be a sliding door to your left that is prob. screwed shut. Unscrew and slide open and the valves are in there.
ksams1 is offline   Reply With Quote
