Old 09-27-2010, 09:12 AM   #1
Draining low water pipes ??
Does anyome know where the low water drain valves on a 2011 Cedar Creek 36RD5S Fifth Wheel are located ?
Trying to learn about my new rig and I can't remeber if the dealer told where the low water pipe drain valves are located.
My other trailer had a low water drain cap for hot water pipes and one for cold water pipes.
Trying to have fun,
Thanks ahead....
gmccall is offline   Reply With Quote
Old 09-27-2010, 11:22 AM   #2
3 Happy Campers's Avatar
Not trying to be a smart a** but have you crawled under the unit yet?
On our new Sierra 5er they were hanging through the underbelly material by about 4Ē. Couldnít miss them.
One was red & the other white.
I actually went to Lowes & got some extra PVC piping & ball valves & ran extensions out to just even with the side of the unit.
Now no more crawling underneath to open the low point drains or the fresh water tank drain.
Not sure why FR doesnít just put the extra $20 into the units & plumb them that way from the factory.
3 Happy Campers is offline   Reply With Quote
Old 09-27-2010, 11:38 AM   #3
Red face
I see several lines underneath but there are no valves attached ??
I had a trailer once where the drain valves were underneath my sink, but I can't find any such valves on this rig.
Old 09-27-2010, 11:43 AM   #4
On mine there were just cap nuts or whatever the technical plumbing term for them is.
I added the ball valves.
You will see two right next to each other. Those will be the low point hot & cold lines. They have cap nuts on them.
Somewhere else under the unit you will find one single line with a cap nut. That's the fresh water tank drain. Right next to that will be a line with no cap on it. That one is the fresh tank overflow.
Old 09-27-2010, 11:50 AM   #5
Yes sir, that is excatly how my last trailer was.
This new rig has no such caps for two drain pipes under mine.
Actually one of the drain pipes with no cap is right next to the drain pipe with a valve that drains the holding tank.
Old 09-27-2010, 11:58 AM   #6
Sorry Iíve offered about all I can at this point.
Donít hesitate to go back to the dealer.
Iíve got mine on speed dial!
The post sale support is what distinguishes a good dealer.
Old 09-27-2010, 01:01 PM   #7
Wanna Be Camper
SaskCampers's Avatar
Not all units have low water drains so it is possible your new one doesn't. The winterizing manual our dealer sent us brings this point up.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 09-27-2010, 01:08 PM   #8
The Cedar Creek 36RD5S is a higher price model than my Sierra 356RL.
I can't see where they would skimp on low point drains on this model.
Iím looking at some pictures on line right now. I wouldnít be surprised if you had some remote valves in the water mgt cabinet. It looks a lot busier than mine.
Old 09-27-2010, 01:13 PM   #9
On my Flagstaff 26RKS they are well hidden but the valve is inside the trailer between the shower and a brace and nearly impossible to get to. While under your trailer, get an idea of the location with respect to the outside and go inside to that location and explore around.
Hokiehall is offline   Reply With Quote
Old 09-27-2010, 01:16 PM   #10
gmccall,
WOW did you get the electronic leveling on your unit? Iím jealous
