Old 05-08-2016, 08:52 PM   #21
BooBoo23's Avatar
Originally Posted by mike.t View Post
Decided to drain the hot water heater today. Little FYI for those(me) who don't do their homework first. Release the pressure first before you remove the drain plug/anode. Holy crap
You now have RV experience. The definition of experience is not making the same mistake twice.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015 - 47
Camped 2016 - 71 2017 3 done - 14 nights reserved
BooBoo23 is online now   Reply With Quote
Old 05-08-2016, 09:38 PM   #22
mike.t's Avatar
Originally Posted by Herk7769 View Post
This thread is an excellent example of why you need to CLOSE the winterizing valves when draining the hot water heater.
It will keep all that crap out of your cold water pipes!
Very nice rig you have there. Mine on the other hand is your basic southern California travel trailer with no need to winterize. Don't think there are winterizing vales my problem I think was not relieving the pressure prior to opening old faithful - Bing video
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is online now   Reply With Quote
Old 05-08-2016, 11:42 PM   #23
Yes I gave done the water in the face once because I didn't turn the water off.
I am about to drain the water heater and fresh water tank and then add 8 gallons of vinegar and 8 gallons of water to the fresh water tank and then run the pump to fill the water heater and then run each faucet until the vinegar smells. The sit for a couple of days and drain and flush. Arizona water can make a mess and I do flush the tank as posted above. This time after the work is done I will remove the relief valve and soak it in vinegar for 3 days and it will look new again. Now all of the story of what I do without knowing if it is a good or not so good of an idea .
labarn
labarn is offline   Reply With Quote
Old 05-09-2016, 07:50 AM   #24
Wolverine 1945's Avatar
Mike,,, sounds like it had been a while since you drained the WH ???
And that you are using a Toilet Wand to flush the WH ???
Not a bad idea !!!
Wolverine 1945 is offline   Reply With Quote
Old 05-09-2016, 08:20 AM   #25
Flybob's Avatar
I took a NPT thread/slip joint adapter and added about afoot of PVC to the slip joint. I thread that into the anode rod hole and insert a spray wand thru it. The PVC section keeps the crud from running down the side of the rv.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 05-09-2016, 08:36 AM   #26
I found last year that when I drained the WH the water was leaking into the storage compartment below,,, hopefully I have fixed that !!!
Old 05-09-2016, 10:42 AM   #27
I felt WET and stupid.....
Det107 is offline   Reply With Quote
Old 05-09-2016, 10:48 AM   #28
I will add to my earlier post. You will feel worse after doing the same thing the 2nd time. Might not be the next time but it can happen. Meaning the story about ya can't fix " " is true. have a great dry camping season.
labarn
Old 05-10-2016, 06:46 AM   #29
Isn't that why we unscrew very slowly,,,
and stop @ the first sign of water pressure ???
LOL !!!
Old 05-10-2016, 09:19 AM   #30
LOL !!!
MAYBE
labarn
drain, heater, hot water, water, water heater
